Speaking of alignment..
My car has needed an alignment for a long time. It pulls to the right. The right front tire is wearing much faster than the rest. A coworker said it was because it is the drive wheel. Does this make sense? (of course they are way over inflated) I want to swap my two front wheels but I guess the only way that's happening is if I actually remove the tires from the rims and reverse them since you can't swap tires on the rims from side to side of the car (from what I've heard). Any suggestions on what I might do about the worn tire aside from replacing it? My dad says it's hard to tire iron a tire off--but it'd be worth the effort to get the other front tire worn down to be even with the other. Anyone have personal experience with tire removal and putting a tire on a rim? Also not sure what doing an alignment will do if one front tire is worn and the other isn't.
Aside from reduced tire wear, will a straight alignment really make a noticeable diff in FE? I'd classify the pull as moderate. If you weigh the car down (especially if the weight is on the right side) then the pull becomes bad/very bad.)
A simpler issue I'm curious about is my clutch. It makes a scrinch noise when I depress it. I don't remember hearing it before--but maybe it's normal. Any other VX clutches go scrinch when you depress it fully?
three stripes the charm!
