Spark Timing - Page 2 - Fuelly Forums
Old 06-13-2007, 06:13 AM   #11
Site Team
Originally Posted by retrorocket View Post
Get a vacuum gauge and see if you can monitor the pulse width of your injectors. Someone on this site should be able to help you there.
If you had an msd ignition box then you could buy an adjustable timing control and adjust it from inside the car and monitor what is happening to the injector pulse width while cruising down the road.
other wise just keep adjusting the distributor, vacuum canister, weight travel, and springs
Get a dial back timing light and plot your timing curve.
Keep playing with it till your mileage seems its best.
Actually, I can get every single bit of data through a laptop, including manifold pressure, injector PW, and virtually everything else.
The trick is right now I am trying to fine-tune the timing tables (did I mention that the computer also controls timing so I don't need the other MSD thing). I cruise around 2400 RPM and about 9-10" of vacuum at 75 MPH.
I had the "cruising" timing at around 50-53 degrees, but I noticed some stumbling (not detonation). I backed it down to 40 and it is smoother. However I think 40 degrees is too low, so I'm trying to find out what other people run for timing on the highway.
I've thought about disabling injectors, but I don't believe that will give any significant savings. I have port injection (not throttle-body) so I could do some nifty wiring and shut down some injectors, but I think that would cause too many other problems.
-Bob C.
Old 06-13-2007, 10:05 AM   #12
omgwtfbyobbq's Avatar
Why do the manufacturers disable the valves?
Probably to minimize vibrations, although I'm sure there's some energy lost from pumping air in and out of the exhaust too, just not as much as friction in a deactivated cylinder. By trapping all the exhaust gases in a given cylinder, maybe increase the size and dampening ability of that air spring?
Old 06-13-2007, 12:03 PM   #13
DRW
All engines are different. The timing that works for one engine may not work for another. From what I recall, a large bore needs more timing than a small bore. Compression ratio has an obvious effect, too. My car has a 2 liter 4 banger with a 7.9:1 comp ratio and likes about 33 to 35 degrees at steady cruise on the freeway. I don't think this timing will work for a 455ci V8.
Dave W.
US / metric switching problems gory Fuelly Web Support and Community News 4 01-24-2011 03:04 AM
Tracking Monthly Fuel Expense Taser Fuelly Web Support and Community News 2 11-10-2009 12:40 AM
Drafting behind a Truck GasSavers_roadrunner Hypermiling 20 12-24-2006 12:17 AM
BMW C.L.E.V.E.R. Concept MetroMPG General Fuel Topics 4 04-24-2006 11:59 PM
