Spark plug mod - Fuelly Forums
Old 05-19-2006, 09:16 AM   #1
zpiloto's Avatar
Spark plug mod
I've had some really good number on my last tank(considering it was mostly city) and lately on my commute. The only thing different besides removing the WAI (which was for about 100 miles) is a spark plug mod found here.http://fueleconomytips.com/index.php...id=31&Itemid=2
I just used the standard NGK plugs regapped at .035 instead of .044 and indexed. These plugs replace the side gapped and index one that were in there. I've got about 350 miles on them. Don't really know how to test this but it sure is not hurting anything and only took about 35 minutes to.
Old 05-19-2006, 09:45 AM   #2
|V3|2D
thisisntjared's Avatar
so wait, all you did was get off the shelf plugs and close the gap?
Old 05-19-2006, 12:35 PM   #3
zpiloto's Avatar
No you drill a 1/16" hole in the bonding strap above the electrode and then dish the electrode a little so that when it fires the spark will go through the hole in the bonding strap for more spark front. There's pictures in the link. It an interesting idea, granted that there is only 2-3% to be gained in this area but every bit helps.
Old 05-19-2006, 01:17 PM   #4
I'm planning on doing extensive plug testing somewhere down the road, it'll be expensive, but whatev, it'll be nice to know also, I say, so yeah.
Anyone know who has the indexing washers now?
Old 05-19-2006, 02:14 PM   #5
krousdb's Avatar
I still have them. Just tell me where to send them.
Old 05-19-2006, 02:16 PM   #6
I guess you dun got my address no mores. I'll pm you with your fancy instant messaging client.
Old 05-19-2006, 02:26 PM   #7
krousdb's Avatar
Got your address via gassavers IM! I know... I am living on the edge.
Will send them out tomorrow. Still waiting for my MID and ECU chips? Should I IM you my address?
Old 05-19-2006, 02:28 PM   #8
Yeah, I guess you should, I lost it in the swap of sites and the whole falling asleep instead of burning you a new chip,
I'll cut your advance in half, just for kicks, shouldn't ping then, but what do I know, I'm pretty worthless.
Old 11-04-2006, 08:28 AM   #9
Spark Plus Socket Size
My 2005 Prius mileage had been as high as 61.3 mpg for a tank of gas over the summer. In the past month, my gas mileage dropped to 57.5 mpg, and the Prius, on occasion, wanted to stall when I accelerated or decelerated - although it never actually did.
I bought a set of Autolite platinum spark plugs to see if maybe the plugs are fouling. Can someone tell my what size spark plug socket I need to use to get the spark plugs out?
c8089923 is offline   Reply With Quote
Old 11-04-2006, 09:06 AM   #10
Why not use plugs with open electrodes.
I have used Magneti Marelli 4 electrode splugs extensively in performance applications.
Or you can use these..
But I have not seen an ounce of FE improvement.
Fuelly ownership change mathowie Fuelly Web Support and Community News 4 08-26-2013 10:39 PM
US / metric switching problems gory Fuelly Web Support and Community News 4 01-24-2011 02:04 AM
Tracking Monthly Fuel Expense Taser Fuelly Web Support and Community News 2 11-09-2009 11:40 PM
TDI EPA figures off? bates General Fuel Topics 14 09-15-2009 08:04 AM
Low Rolling Resistance Tires SVOboy General Fuel Topics 33 04-04-2006 07:57 PM
