Spark plug mod - Page 3 - Fuelly Forums
Old 07-22-2008, 08:04 PM   #21
cut back the ground trap
COMP is offline   Reply With Quote
Old 11-07-2008, 07:21 AM   #22
Does anybody have a line on some indexing washers?
Any FE gains to be had by changing the heat range of your plugs?
The Z1 calls for a heat range of '4'.
I wonder of a '5' or '6' (with correct gap) would show any FE gains?
Low number = cooler plug
High number = hotter plug
For FE gains = cool or hot?
1984 Volvo 242Ti (in storage) Boost+Bosch CIS = :cry:
2004 Pilot EX
2008 Fit Sport
GasSavers_Willard is offline   Reply With Quote
Old 11-07-2008, 07:42 AM   #23
The heat range all depends on the company. In the NGK scale a 4 is hotter than a 5 or 6. The only reason you would see gains from going to a 5 and maybe a 6 would be because you are getting pre-ignition from a plug running too hot. I'd be weary about running a 6 in a car meant to have a 4. The colder you get the more likely the plug will foul and/or get buildup on it that will cause misfiring.
Champion and Bosch have a lower number for a colder plug. NGK and Denso go higher.
Your engine uses the following and if it has stock compression you only want to go up one step from that at the most. With Champion and Bosch they have a couple of heat ranges that are so close to each other that you can pretty much select from a small group of heat ranges.
NGK 4 -> 5
Denso 14 -> 16
Champion 11,12 -> 9,10
Bosch 8 -> 6,7
- Kyle
Old 11-07-2008, 10:54 AM   #24
guest001's Avatar
where the hell do you get the washer to index plugs??
guest001 is offline   Reply With Quote
Old 11-07-2008, 11:00 AM   #25
Summit:
http://store.summitracing.com/egnsea...115+4294854256
(Not sure of the correct size/style).
I may pick up a set (for me and a few friends).
I just wonder which direction the electrode should point in a Z1.
I was thinking towards the timing belt... but who knows.
2004 Pilot EX
2008 Fit Sport
Old 11-07-2008, 11:02 AM   #26
I have a set of 6's in my Z1 (with a 4 wire 02 and chipped P-28) (there is no issue that I can tell).
I was wondering if a set of 5's (or back to the OE 4's) would give any FE gain.
I will be back on the dyno (loading) in a few weeks and want to pick them up before then.
2004 Pilot EX
2008 Fit Sport
Old 11-07-2008, 11:11 AM   #27
The ground strap should be on the exhaust side of the chamber.
- Kyle
Old 11-07-2008, 12:47 PM   #28
Originally Posted by krousdb View Post
I still have them. Just tell me where to send them.
Where can you buy the indexing washers? I need to get some too. Disregaurd this post I posted before reading everything.
Hipermiler
#47 on my way to #1
Old 11-07-2008, 02:00 PM   #29
guest001's Avatar
I heard about this a long time ago. so how would you firgure out which washer to use?? keep trying them until you find the washer that indexs correctly??
Old 11-08-2008, 11:50 AM   #30
You have to keep trying until you get it right.
Hipermiler
#47 on my way to #1
Fuelly ownership change mathowie Fuelly Web Support and Community News 4 08-26-2013 10:39 PM
US / metric switching problems gory Fuelly Web Support and Community News 4 01-24-2011 02:04 AM
Tracking Monthly Fuel Expense Taser Fuelly Web Support and Community News 2 11-09-2009 11:40 PM
TDI EPA figures off? bates General Fuel Topics 14 09-15-2009 08:04 AM
Low Rolling Resistance Tires SVOboy General Fuel Topics 33 04-04-2006 07:57 PM
