Someone Has Built An Efie ? - Fuelly Forums
Old 02-04-2007, 12:16 PM   #1
SIFLIGINIUS's Avatar
Hi to All!
I has built an EFIE and into an AFRD.
I want to compare readings of leds, flickerings and functioning at idle and higway.
Thankfully
SIFLIGINIUS is offline   Reply With Quote
Old 02-04-2007, 04:52 PM   #2
GasSavers_roadrunner's Avatar
That was soooooooooooo funny!
GasSavers_roadrunner is offline   Reply With Quote
Old 02-04-2007, 04:59 PM   #3
Tuggin at the surly bonds
Silveredwings's Avatar
Clencher...Is that a rabbit with a flat-head?
Old 02-04-2007, 05:02 PM   #4
zpiloto's Avatar
Here you go http://www.eagle-research.com/FAQ/FS/efiefaq.html
Old 02-04-2007, 07:04 PM   #5
That's not a bunnie with a pancake on its head . . . that's a bunnie with TWO pancakes on its head.
Old 02-04-2007, 08:41 PM   #6
GasSavers_Ryland's Avatar
WTF???
Is there a problem with writting full words? at least use the full phrase at least once (in brackets?) so you are not just reading thru a whole list of initials without having a clue what they meen or are we too good for that, it does after all seem like a good way to keep this a nice little elite club, keep those pesky outsiders where they belong, in the dark!
Old 02-04-2007, 08:59 PM   #7
I agree, there are way too many TLAs tossed about.
(TLA=three letter acronyms)
Old 02-05-2007, 03:26 AM   #8
Moderator
GasSavers_DaX's Avatar
It sounds like a meeting at work. The airline industry is polluted with TLA's.
Old 02-05-2007, 06:51 AM   #9
bones33's Avatar
Originally Posted by SIFLIGINIUS View Post
Hi to All!
Thankfully
I use an efie built by eagle research (not me) and a cheapo $30 jc whitney afr display. It's cranked down as lean as possible without excessive driveability problems but still have a little bucking at some very light throttle settings (no idling along in 5th). It usually cycles from one to two sometimes up to five bars from the bottom (lean) on the freeway. This is supposed to indicate something like 17:1 or so but there is no way this cheap afr gauge is anything but an approximation. Normal cycling without efie is right in the middle as it should, cycling up and down on either side of stochiometric a few times a second. This is with my dual plug head ford 2300cc motor. The nissan 2400cc wouldn't run near this lean, but it only had a single plug head.
As always, tune the efie to your particular engine, the instructions are pretty accurate actually. Using an afr with the efie in my opinion is a great idea, you really need some feedback for how the efie is affecting your fuel mixture, seat of the pants tuning leaves too many opportunities for error.
Old 02-05-2007, 07:52 AM   #10
Electronic Fuel Injection Enhancer = EFIE - modifies the Oxygen Sensor Signal to the ECU - Engine Control Unit (two are needed if two oxygen sensors are being used)
Air Fuel Ratio Display = AFRD
Filter for cars that aren't being updated? stan0101 Fuelly Web Support and Community News 7 08-29-2010 10:39 AM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 03:13 AM
US/Imperial mpg figures HTWB Fuelly Web Support and Community News 6 11-26-2008 11:31 PM
Reporting capabilities via SMS? hidesertmlb Fuelly Web Support and Community News 4 09-02-2008 12:02 AM
Need way to indicate a missed fuel-up entry exists silente Fuelly Web Support and Community News 7 08-20-2008 07:46 AM
