Some more bump starting discussion - Page 2 - Fuelly Forums
Old 08-14-2006, 06:08 PM   #11
Hey I rolled down a parking lot a few weeks ago and bump started my xB - it started easier than using the starter motor . . . leads me to believe that I have some battery cable issues maybe . . . anyway working on a 450 mile tank and the gas light came on - another fillup tomorrow at S&S with my 10 cents a gallon discount coupon - got three of the suckers and can't burn the gas fast enough to use them before they expire next month on the 23rd.
Also just took about 50 lbs of "junk" out of the back - tools and stuff in boxes I was lugging around - need to check out the back seat removal next.
Old 08-14-2006, 07:09 PM   #12
Compaq888's Avatar
I bumpstarted it again today. I still need to learn how to make it smooth. I'll be working on that next.
Old 08-18-2006, 05:48 AM   #13
I've been successfully bumping with my '92 Civic and have added the technique of letting out to start and then quickly putting back in. Every once in a while the car fails to start which leaves me in a bad spot. I think it might get flooded somehow since if I pull over and crank it it still won't start but if I open the throttle then it catches. Anyone else experience this?
Sean
Sean88 is offline   Reply With Quote
Old 08-18-2006, 09:38 AM   #14
Sounds like your main relay is going! I need to do my write up!
Old 08-18-2006, 12:20 PM   #15
GasSavers_brick's Avatar
I've experienced no-starts if I jump the gun on disengaging the clutch after the first bump, but 99% of the time I'll get it on the second try. 1% of the time I'll just give up and key-start if I've lost too much speed, but I have yet to have the key fail me. (I better go knock on wood or something...)
'07 Toyota Prius
Old 12-28-2006, 01:00 PM   #16
AlexK's Avatar
I tried a bump start in 5th gear at 40 mph and it wasn't that violent. I was expecting the tires to chirp and the car to lurch when I popped the clutch but it wasn't that bad. So what is the advantage to injector cutout over ignition kill? With ignition kill there would be a fresh fuel charge in the cylinders and an easier restart, right?
AlexK is offline   Reply With Quote
Old 12-28-2006, 01:30 PM   #17
CO ZX2's Avatar
I would not POP the clutch. Let it out gently, helps cushion the shock.
I had ignition kill switch first but seemed to take too long for the engine to die. Also think that the injectors may dribble gas, mine seemed flooded at times on restart.
I really like the injector shutoff, engine shuts down immediately and starts cleanly.
Old 12-28-2006, 03:30 PM   #18
FE nut
diamondlarry's Avatar
What I usually do is let the clutch out far enough to start the engine then quickly shove it back in to let the engine come up to speed before continuing down the road.
2007 Prius,
Team Slow Burn
Old 12-29-2006, 02:23 AM   #19
AlexK's Avatar
From a conservation of energy standpoint, letting the clutch out slowly wastes energy (slows the car down while the transmitted torque builds up enough to overcome the compression and start the engine). It also wears the clutch pads. Popping the clutch wears the clutch less and saves energy but jolts the drivetrain more. My experiment showed me that the jolt isn't too bad in my car.
Maybe this should be in it's own topic. Do you guys double clutch when shifting from neutral to say 5th gear after a P&G cycle? I do to save wear to the synchros in my transmission. You can't double clutch when the engine is off, so there will be some synchro wear happening.
I am obsessed with FE but more obsessed with mechanical wear. From my experiences with many cars, the transmissions and drive trains break before the engines wear out (with proper oil changes). I need to decide if the increased wear and hassle is worth the FE benefit.
Old 12-29-2006, 05:31 AM   #20
If you start engine-off coasting, Alex, your MPG is going to go throught the roof
Partial Fuel-up Calculations Improvements ryogajyc Fuelly Web Support and Community News 16 04-17-2012 09:25 AM
Partial Fuel Up - Calc Improvement suggestion RadarKen Fuelly Web Support and Community News 1 11-23-2011 08:17 AM
Location awareness! moxfyre Fuelly Web Support and Community News 11 03-16-2011 01:36 AM
Jetta TDI 2009, Do the chips help tak2asprin General Fuel Topics 14 07-17-2009 05:18 AM
Sort by MPG billcharlton Fuelly Web Support and Community News 2 09-18-2008 05:00 AM
