So how much oil for best fuel economy? - Page 2 - Fuelly Forums
Old 03-20-2006, 04:40 PM   #11
Quote:Seriously did you have
Seriously did you have an oil temp gauge when you ran this test?? Never heard of the pressure dropping due to oil level in the pan.
This is common with hondas. VTEC you might know is oil pressure sensitive. The first thing the check when your vtec stops working is the oil pressure, if it's too low, you top off your oil to make sure it's full and you can get full pressure to engage m@d vtaK y0!
Old 03-22-2006, 04:53 PM   #12
Re: Quote:Seriously did you have
Eko that S-man. I juiced it low and crunked the vtaK in my ess-EyE. Thought I f***ed it all up in there. Turnz out da slick stuff was lo-down. Took a rookie visit to the D-L-R to get the info y0!
Seriously, took a corner quickly, autocross style, and the VTEC went into "safe mode". I honestly thought I srewed up badly. Just took a quart of oil or two and things were back to normal. It just used it up quickly for some reason.
But to answer the question, most cars here are older and might use some oil between changes. I like to have it full to the recommended level for safety purposes. The oil pump will pump the same amount of oil unless you're nearly out, which can improve mileage while coasting on a locked-up engine.
Pulse and Glide? Pete7874 General Fuel Topics 24 02-26-2009 12:11 PM
