Simple Gear Calc program - Fuelly Forums
Old 04-03-2008, 12:26 PM   #1
I love playing with these to find the best gearing solution for better mileage.
I found this on a F-body web site. Any car will work. It asks for your tire size, final ratio, Max RPM, and transmission gear ratios.
Then shows you the rpms in 100's what speed you would be running in each gear. I was comteplating doing a gear change for better highway mileage in my Volvo 960. Stock the car came with 3.73 rear gears. When I played with 3.54 and 3.31 rear gear sets I found that the 3.54's were the best option of the two. The 3.54 would drop the rpms by about 100 rpms at 65 mph. The 3.31's would drop the rpms by 200. Two hundred rpms brings the rpms down too far to be a benefit.
BTW every time you click calculate it opens up a new spread sheet below the one before it. So if you change something and hit calculate you can compare the changes with the previous calculation by scrolling up or down on the page.
Gear Calculator/
GasSavers_ALS is offline   Reply With Quote
VX rear wheel hubs -anyone replaced theirs? jadziasman General Maintenance and Repair 13 06-15-2007 11:16 AM
tire warped because of too much psi kickflipjr General Fuel Topics 30 04-24-2007 12:09 PM
Happy Holidays everyone! Matt Timion General Discussion (Off-Topic) 10 12-29-2005 11:07 AM
Anyone know how to get Tree Sap off the car??? Compaq888 General Discussion (Off-Topic) 4 12-16-2005 03:11 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 04:53 PM
