Short Ram intake == Warm Air? - Fuelly Forums
Old 11-28-2007, 07:49 PM   #1
GasSavers_Minger's Avatar
Out of curiosity, would it achieve the same purpose?
Ant I know this is going to be a bad question, but how are eBay parts...I see a short ram for 20, but common sense screams not to get it
P.S. I must be a wierdo as I think just because a guy can afford to do something, doesn't mean he should. I can afford to buy 100 gallons of gas several times a month, pour it on the ground, light it (or not)... but I don't think I should.
GasSavers_Minger is offline   Reply With Quote
Old 11-28-2007, 08:30 PM   #2
The ebay intakes aren't too bad. It's pretty hard to screw up metal tubing as long as they get the bends right.
They're using 'ram air' for marketing. In reality, you're right about it bringing in hot air. The hot air is less dense which means that EFI will inject less fuel, so I guess it'd make sense for FE.
I see no reason why fuel economy and power cannot coexist.
DrivenByNothing is offline   Reply With Quote
Old 11-28-2007, 08:52 PM   #3
Danronian's Avatar
I had one on my VX and I found the powerband wasn't very smooth compared to with the OEM intake. It was also much louder, and my car warmed up in twice as long since the factory one pulls all the air from the engine bay instead of the unsealed short-ram which can pull the air from wherever it is hit with flow.
Old 11-29-2007, 10:47 AM   #4
kamesama980's Avatar
except that most often car manufacturers sacrifice real world FE or real world speed/performance for paper HP and emissions ratings. That's why you CAN improve power and mileage over stock with intake pipes, headers, exhaust work.
Yes, you'll hear more induction noise (hissing under load) and more than that, it depends on the specific kit vs your stock setup. some can barely be improved upon, some are terrible
-Russell
Old 11-29-2007, 11:55 AM   #5
Well, then...food for though, as it looks like Im going to be stuck with this civic for another 2 years... you guys think it would be a good idea to get a cheap one, and if so..now, or wait until it warms up to do so?
Old 11-29-2007, 05:30 PM   #6
kickflipjr's Avatar
I short ram intake probably will not improve mpg because the car will be getting my air and wasting more gas to keep everything at an equal ratio. Plus 3" tubing will not help wind speed velocity at all. A "whale penis" might show some improvement.
I doubt vx intake tubes are compatible with a 2004 civic, but for earlier year civics switching to a vx tube would show improvement (along with power loss under high load).
2008 EPA adjusted:
Old 11-29-2007, 09:30 PM   #7
I'm sorry, but that didn't make any sense to me.
Old 11-30-2007, 05:11 AM   #8
ZugyNA's Avatar
WARNING! Obtaining one of these might be a hazardous undertaking. The whale might object...and you'll get all wet.
Questions about getting HX rims for 99 civic. Compaq888 General Maintenance and Repair 8 06-05-2009 07:56 PM
Need way to indicate a missed fuel-up entry exists silente Fuelly Web Support and Community News 7 08-20-2008 08:46 AM
