Shell's Nitrogen Enhanced Gasoline. - Page 5 - Fuelly Forums
Old 03-10-2009, 07:10 PM   #41
3 thoughts
First off, had a 70 F250 Ford pickup with a camper on it. 360 V8 2 barrel, 4 speed, 7 mpg. Went through 3 engines, one every 125,000 miles, when I rebuilt the first and second one, my valves looked like that. At 125k the engine would drink oil and blow smoke, so if the Shell ad portriats that valve, it has to be one whooped engine, but this is old iron block technology.
Second, it has been said that we only get 4 sources for gasoline, isnt there some giant gas lines that trasport the nations fuel around America. I understand that cheap gas is less filtered and has less cleaners and additives. As far as I can think, this nitrogen enrichment is just a fancy fuel cleaner?
Third, I ran my last 2 tanks of Shells new nitrogen enriched fuel and have seen nothing in the way of increase or decrease in fuel economy. I just figure Im getting the added benefit of not having to stop at Auto Zone and buy fuel system cleaner.
Old 03-10-2009, 07:42 PM   #42
Yes, the raw gasoline is transported through the same pipelines throughout the country, but the additive package is added when the fuel truck is filled to go out to your local filling station. The additives do not go through the pipeline.
Old 03-14-2009, 06:22 PM   #43
brucepick's Avatar
Hmmm -
For those of us driving Honda lean burn cars (VX, HX, and maybe Civic Hybrids?) -
Can the nitrogen content cause increased NOx in the exhaust? The cat converter will need to handle any increase in NOx.
I ask about this because I've been filling up with Shell - and am battling to keep the 97 HX in Lean Burn. I won't be buying any Shell gas for a while to see if things improve.
Any comments, from readers who are familiar with the Honda Lean Burn system and who have a stronger background in chemistry than I?
Old 03-14-2009, 09:50 PM   #44
I just filled up the beast with "Nitrogen Enriched" Shell 93 octane. We'll see what happens...
Old 03-26-2009, 07:26 PM   #45
I just tried a tank of the "nitrogen enriched " Shell when I was over in Vermont. Didn't seem to do anything for my gas usage. I guess you have to run a couple of tanks of it to make sure you are running it straight without any other gas to give it a fair review. I am unable to do that as there are no Shell stations in Upstate NY. I tried anyway.
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 03-28-2009, 05:20 PM   #46
just finished a tank of shell 93 octane. it is the best FE i've had in a while, but i cannot attribute that to the gas.
higher temps and a new MAF sensor(previous tank) no doubt had some influence. my miles are VERY similar tank to tank making for good testing, but next tank will consist of some vacation miles.
suspend experiment and resume later...
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
crude going up WAY UP GasSavers_BEEF General Discussion (Off-Topic) 15 06-11-2008 06:34 PM
I hate my ScanGauge!!! 2TonJellyBean Hypermiling 14 11-29-2007 10:16 AM
Honda Accord Hybrid Dies budomove Hybrid Vehicles 13 06-06-2007 09:55 AM
Do gals not want to save gas? zpiloto General Discussion (Off-Topic) 22 01-19-2007 09:54 PM
