I just got off the phone with Linear-Logic. I was told by a tech that although it allows you to scroll through a number range, the only relevant settings are 0 or 24. A value of 24 allows the SG to read 9999 when the engine has cutoff fuel to the engine above 1000 RPM. A value of 0 doesnt allow the SG to read 9999, just a high number during those coasting situations...
So if your car does shutoff fuel at a certain RPM range while coasting in gear, then leave it at 24. If it does not, put it at 0. These are the only 2 options that have an impact on the SG readings according to the tech I spoke with today.
