Scanguage II Calibration: 'Adjustment Factor on Fillup' - Fuelly Forums
Old 11-01-2006, 01:44 PM   #10
Originally Posted by MetroMPG
Cool. How are you going to test it?
Well I record the reading of the pump and the ScanGauge calculated use and know that the tank only holds so many gallons and it has in the past taken 10 gallons to fill when on the low light so if it consistantly takes less gallons to fill than expected then it should be pretty clear something is going on. Cold weather for the weekend and I will be gassing up in Newport Maine HA HA so I should get a cold tank full yielding even better gas mileage. Other than that it would take a 1 gallon container or a bigger calibrated container. Anyone want to purchase 1 gallon of slow pumped gas and then measure it later in a calibrated container?
Old school cylinder deactivation MetroMPG General Fuel Topics 11 06-09-2006 06:29 AM
Water Fuel System diamondlarry General Fuel Topics 0 11-14-2005 12:20 PM
