Scan Gauge 2 How it works - Page 2 - Fuelly Forums
Old 06-17-2007, 06:41 AM   #11
Snax's Avatar
I don't believe that is true anymore. The fact is, manufacturers have determined that the old narrow band oxygen sensors which make keeping a perfect stoiciometric ratio an easy target are inadequate for optimal power and efficiency. The use of wideband sensors has opened up the ability to tune more accurately to both ends of performance and efficiency - allowing them to carefully control ratios far leaner than the standby 14.7:1.
I don't believe that all modern cars have a lean burn mode, but there are certainly many more now that do.
LiberalImage.com
I think, therefore I doubt.
Old 06-17-2007, 06:52 AM   #12
Snax's Avatar
Answering the original question, I'd bet that SG actually uses injector pulse width as the primary means of metering fuel. When you first plug it in, it assumes an average rate of injector size for a given engine displacement and calculates fuel used based on the length of the injector on-time. The user calibration that you can do afterward is simply a way to correct for the assumed values of consumption, as it's a fairly linear relationship that does not change significantly with variations in atmospheric conditions.
LiberalImage.com
Old 06-17-2007, 06:50 PM   #13
Thanks guys. Hijack over.
Old 06-18-2007, 03:46 PM   #14
GasSavers_Ryland's Avatar
does it do anything to moniter manifold vaccum, so it can figure out what the fuel presure regulator is doing? or does it just figure an average fuel presure?
Old 06-20-2007, 01:44 PM   #15
Mentalic's Avatar
I agree, the scangauge must use injector pulse's as the primary method of accounting for fuel burn. Otherwise while maintaining the same RPM on cruse you should always see the same fuel burn/mpg rate yet it does not. I flip on the A/C I see a few mpg drop, a truck changes into my lane and my MPG jumps up.
Mentalic is offline   Reply With Quote
Old 06-20-2007, 05:46 PM   #16
I don't know how it works but I know that on a Saturn the IAT has a huge effect on the reported mileage. I asked Ron about this and never got a reply. You can deceive your self about 20% if you want .
I have been considering installing an IAT resistor just to get more consistent results.
usedgeo
Publishing Fill-up Stats from Mobile Site? smknipe Fuelly Web Support and Community News 2 06-22-2011 05:27 AM
Price/Mile is very useful data Don65Stang Fuelly Web Support and Community News 8 06-15-2011 05:27 AM
Why is AT less efficient? caprice Transmissions and Running Gear 28 03-23-2007 11:58 AM
99 civic ex (hello) requiem Introduce Yourself - New member Welcome 6 02-06-2007 07:38 AM
Garage Update Rstb88 General Discussion (Off-Topic) 3 10-16-2006 09:07 AM
