Running a WAI through the wringer - Fuelly Forums
Old 08-26-2010, 09:55 AM   #1
Lean Burn Mode
pgfpro's Avatar
Re: Running a WAI through the wringer
the IAT temps seem to be around the range that I usually run.
the coolant temps you are talking about are pretty scary to me. I would definitely change something. we have seen quite a few 90+ degree days this past summer (maybe a few 100 degree) and my temps run right around the 190 mark. not sure but I think I have a 195 thermostat.
it really isn't worth screwing up your motor. I will say that you stayed with it and gave it a descent go but maybe it is time to move on from this as your intake temps probably are pushing your coolant temps up at least to some extent.
and power does go down the crapper. once you hit the 200ish mark for IAT, you really notice it.
I would also be very careful not to push it to much with these high ect's.
Your car is on the verge of going into limp mode to save the engine.
Average mpg + tracked km even though fuel-ups marked as missed Pelle Fuelly Web Support and Community News 14 03-04-2012 03:10 AM
consious driver. slurp812 Hypermiling 13 08-24-2011 08:07 PM
new member dirtygst Introduce Yourself - New member Welcome 13 03-31-2009 06:46 AM
Column Shifter dletm08 General Discussion (Off-Topic) 6 03-30-2009 09:48 PM
CRX + D15Z1 Timing/CEL Question MakDiesel General Maintenance and Repair 1 03-20-2008 04:53 PM
