Running a WAI through the wringer - Page 10 - Fuelly Forums
Old 04-01-2010, 10:30 PM   #91
Banned
no one cares-in response to spammer...
Old 04-02-2010, 08:29 AM   #92
FrugalFloyd's Avatar
I've been out of town on a road trip the past 2 weeks, driving my SE-R (averaged ~39 mpg over 2500 miles). I'll wrap my WAI and tape it soon. Then I'll be ready for another round of tests.
Yes, fiberglass insulation doesn't burn, being essentially sand. Of course, iron shouldn't burn either, but toss some powered iron into a fire, and you'll learn differently.
Old 08-11-2010, 09:23 PM   #93
Re: Running a WAI through the wringer
Remember this project? I finally insulated my WAI, and will do some ABA testing in about a week. Following photo shows the wrapped WAI.
Old 08-12-2010, 02:43 AM   #94
I'm getting itchy just looking at it.
Old 08-12-2010, 03:35 AM   #95
Now that looks worthwhile.
Glad to see you haven't given up hope and you're giving it another try.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 08-12-2010, 06:17 AM   #96
GasSavers_WD40's Avatar
I did exactly the same setup as the scion in the pics but on my 07 yaris, and the results were virtually no dif, lots of extra heat in the intake but the computer decides everything and thats all there is to it.
You can do anything you want that should make a dif, but the computer will over-ride it all. Thats why i sold the yaris for a 92 VX. At least its designed to get better MPG from the get go.
GasSavers_WD40 is offline   Reply With Quote
Old 08-14-2010, 09:34 PM   #97
I drove the SE-R down to San Diego for the weekend, or I'd have gone out and run the tests already. I'll probably run them midday, so there'll be minimum temperature change between tests.
It would be a bummer if this test also shows no improvement.
Old 08-15-2010, 06:02 AM   #98
Bummer yes. In reality though, it's been said time and time again; some cars it works wonders on, others not so much.
John
'01 KTM Duke 2
Old 08-19-2010, 05:46 PM   #99
Well, I did my ABA testing with the insulated WAI today. Ambient air temp was 66 degrees when I left the house. 9.7 miles of P&G later, I arrived at my testing area, with the xB warmed up. Water temperature (FWT) was 195 degrees, intake air temperature (FIA) was 100 degrees, and my mpg for the drive out was 52.3 mpg.
First, I did a B test, since I had the WAI hooked up over the exhaust manifold. I reset the Scangauge, got up to 31 mph in 5th gear, set the cruise control, and let her run. 19.3 miles later, I averaged 54.0 mpg. FWT was 202 degrees, and FIA was 127 degrees. It got as high as 138 degrees climbing one hill, and was at 130 degrees most of the run. This was a 30 degree improvement over the uninsulated WAI from earlier testing, and about 60-65 degrees over ambient temperature.
Then I did A testing, routing the WAI off the exhaust manifold and back behind the radiator, simulating the OEM air horn position. My WAI did its job during the earlier test. The FIA display during the A run ranged from 91 to 96 degrees during most of the test, 31 to 47 degrees lower than temperatures from the WAI position. FIA during most of the run was 94 degrees, an average of 36 degrees cooler than the WAI B run. But what mpg did I end up with? At the end of this A test, FWT was 202 degrees, FIA was 94 degrees, and my average mpg for this 19.3 mile drive was 54.1 mpg, nearly identical to the previous run.
I switched back to the B (WAI) position and did another test. At the end of the drive, FWT was 204, FIA was 127, and mpg was 54.1, identical to the OEM simulated air intake position. Ambient air temperature might have increased 5 degrees during all the testing. I left the windows cracked during all tests, and never needed to run the AC. Wind was minimal, under 5 mph during all testing.
I P&Ged back home, with the WAI in B position, averaging 61.4 mpg for the 9.7 mile drive, with FWT at 195 degrees, and FIA at 114 degrees. P&G is pretty easy on engine temperatures and much better for mpg.
I think I can now make the statement that, based on scientific, controlled testing, a WAI provides no significant mpg difference in my car. Coupled with Darin's results at metrompg.com, the two best scientifically controlled WAI tests show no benefits from WAIs. Now the burden of proof falls on those who claim WAIs work in their cars, to do similar testing to prove it.
Old 08-19-2010, 06:22 PM   #100
Summing it up:
Insulated WAI results from 8/19/10
B1 (WAI) test 31 mph CC = IAT 127?, ambient 66?, 54.0 mpg
A1 (control) test 31 mph CC = IAT 94?, ambient 66?, 54.1 mpg
B2 (WAI) test 31 mph CC = IAT 127?, ambient 69?, 54.1 mpg
Uninsulated WAI results from 3/6/10
A1 (control) test 31 mph CC = IAT 73?, ambient 51-55?, 53.3 mpg
B1 (WAI) test 31 mph CC = IAT 100?, ambient 60?, 54.2 mpg
A2 (control) test 31 mph CC = IAT 76?, ambient 65?, 54.3 mpg
B2 (WAI) test 31 mph CC = IAT 100-103?, ambient 70?, 54.8 mpg
A3 (control) test P&G = IAT 73?, ambient 65?, 64.7 mpg
B3 (WAI) test P&G = IAT 91?, ambient 70?, 65.8 mpg
I think it's pretty cool that 5 months later, my CC results are so consistent compared to my earlier testing. All those cruise contol tests are within a 1.5 mpg spread.
Average mpg + tracked km even though fuel-ups marked as missed Pelle Fuelly Web Support and Community News 14 03-04-2012 03:10 AM
consious driver. slurp812 Hypermiling 13 08-24-2011 08:07 PM
new member dirtygst Introduce Yourself - New member Welcome 13 03-31-2009 06:46 AM
Column Shifter dletm08 General Discussion (Off-Topic) 6 03-30-2009 09:48 PM
CRX + D15Z1 Timing/CEL Question MakDiesel General Maintenance and Repair 1 03-20-2008 04:53 PM
