Rolling Resistance - Fuelly Forums
Old 09-25-2006, 01:53 PM   #1
omgwtfbyobbq's Avatar
Rolling Resistance
Does anyone have any info on what bearing friction is compared to rolling friction? I've seen that increasing tire diameter lowers rolling resistance marginally, but I haven't found anything stating why it does that. Since rolling resistance is supposedly caused by both the ground and tire deforming, it follows that a harder compound and more pressure reduce the tire deformation and rolling resistance, but increases in diameter shouldn't do anything between the tire and the road. It will however, result in the bearings spinning less compared to the tire, so if the resistance of the bearings/races is greater than the resistance of the tire/ground, an increase in diameter should minimize this up to a point, and lower the total force the tire has to overcome. Thoughts, doughnuts, skunks?
Anyone (who doesn't have sealed bearings, I H8 'em ) try synthetic greases?
Old 09-26-2006, 02:44 AM   #2
GeoMetry's Avatar
Another thing to concider is the rotational weight. In general when you increase the diameter you end up increasing the weight of the wheel/tire. I don't claim to understand it but this is something that can have a measurable negative effect.
GeoMetry is offline   Reply With Quote
Old 09-26-2006, 03:08 AM   #3
Tuggin at the surly bonds
Silveredwings's Avatar
I would think the larger diameter would have atleast 2 (qualitative) effects:
1. the larger diameter tire might mean less angular deflection where the rubber meets the road (sorry ).
2. a larger tire should much more easily roll over the irregularities in the road surface.
Old 09-26-2006, 03:12 AM   #4
All sounds to me like a good reason to drive slower.
Old 09-26-2006, 03:15 AM   #5
I didn't think rolling resistance was speed-dependent.
Old 09-26-2006, 03:32 AM   #6
just a little dependant - linear - not exponential like air drag
Old 09-26-2006, 12:57 PM   #7
Hi Silveredwings, aren't No.1 and No.2 the same thing (1=>2), or for that matter, how much does angular defelection depend on tread/pressure? What about the additional weight of a larger wheel/tire?
I had a comment that states that a reduction bearing rotation helps, a little.
Bearing drag is fairly low compared with tire resistance, but increasing the ratio of wheel diameter to bearing diameter will help. A little.
And also that
If the width, load and pressure are the same, bigger diameter should have less tread and sidewall distortion, so it should have lower losses due to hysteresis, however it will have a higher polar moment.
So, fewer losses due to tire flex, but more mass. Given how much compound/tread desgn seems to play a part it seems like size isn't much of a concern at all... Which seems pretty obvious after checking out greenseal's 2002(?) report.
Old 09-26-2006, 03:33 PM   #8
If that was true then Bicycle tires would be small. The bottom has to be flat to match the road so the larger the diameter the less it has to flex to get flat on the road.
Old 09-26-2006, 04:11 PM   #9
But bicycle tires are small.
Old 09-26-2006, 04:32 PM   #10
26 inch diameter about the size of a car tire is not what I consider small - 10 -12 inches is small.
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 06:00 AM
Data/Chart Discrepancy PTH Fuelly Web Support and Community News 3 07-02-2010 08:14 AM
Graphs itsastationwagon Fuelly Web Support and Community News 2 08-13-2008 03:04 PM
Both odometer and trip mileage? tiffehr Fuelly Web Support and Community News 1 08-08-2008 05:55 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 08:27 AM
