Rolling Resistance - Page 2 - Fuelly Forums
Old 09-26-2006, 05:23 PM   #11
omgwtfbyobbq's Avatar
Oh you mean wheel diameter. If you hold a 26" bicycle wheel/tire up to a 14" car/tire you'll find they aren't very far off in terms of size (for instance my road bikes tires/wheels are only a few inches taller than the 13" tires/wheels on my car, and a bit smaller than the 15" tires/wheels on my truck), since car tires have way more sidewall compared to bike tires. The change in angle wrt the outer diameter isn't very different. In fact, other confounds, like lack of a suspension in many bikes, leads to small bike tires having a lot of give to them, so it's not exactly a tomato tomatoe deal compared to cars, where the suspension dissapates energy from rough riding.
Old 09-26-2006, 06:35 PM   #12
Tuggin at the surly bonds
Silveredwings's Avatar
Originally Posted by omgwtfbyobbq
Hi Silveredwings, aren't No.1 and No.2 the same thing (1=>2), or for that matter, how much does angular defelection depend on tread/pressure? What about the additional weight of a larger wheel/tire?
I had a comment that states that a reduction bearing rotation helps, a little.
And also that
So, fewer losses due to tire flex, but more mass. Given how much compound/tread desgn seems to play a part it seems like size isn't much of a concern at all... Which seems pretty obvious after checking out greenseal's 2002(?) report.
regarding 1 vs. 2: You make a good point. I do think they are different. Treadflex on smooth ground may prove to be more a function of the tire's design, whereas a tire's ability to roll over irregularities seems to be a direct function of diameter. Look at exaggerations: which would be more difficult to roll over a curb, a 3" wheel, or a 60" wheel? The road just seems to be a series of irregularities.
Old 09-26-2006, 07:08 PM   #13
Ah I gotcha, the designated inflation pressure can be different for different tires which impacts treadflex, but diameter/mass is directly related to the polar moment and the ability to roll over much rougher obstacles. I see... Thanks for the info!
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 06:00 AM
Data/Chart Discrepancy PTH Fuelly Web Support and Community News 3 07-02-2010 08:14 AM
Graphs itsastationwagon Fuelly Web Support and Community News 2 08-13-2008 03:04 PM
Both odometer and trip mileage? tiffehr Fuelly Web Support and Community News 1 08-08-2008 05:55 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 08:27 AM
