Originally Posted by Mentalic
Finally installed the fan today, took most of the day as well. Only ran it a bit to verify operation so I don't know the FE impact just yet. I removed the lower grill block until I feel confident in this new setup.
I'm going to be adding 2 smaller fans to a 4 cyl Nissan 4x4. Only issues I see with your setup is that by shrouding the fan...you might reduce the airflow you have from just the truck moving forward...though your efficiency is increased when the fan runs.
I'm going to be using a mechanical adjustable fan switch where I put the sensor bulb (covered by silicone gasket goop) inside the coolant hose coming from the engine. I adjust these on the road by watching the temp gauge...I only want the fan to run if the gauge starts to rise above normal. This switch is on/off at one temp.
I also use a fan indicator light so I know when it is running.
I find that placing the sensor on the outside of the rad or a hose does not allow very accurate control of the fan.
My opinion is to max out the natural air flow as much as possible by not using a shroud...and be sure the fan(s) only run when really necessary. Otherwise you run the risk of spending time and $ and might be not much better off than you were mpg wise. Not using a shroud might cause overheating on the trail though.
But I haven't actually done this yet...so who knows. The fan switch I have installed in another vehicle and it works as expected....rarely runs.
