repair / clean Oxygen sensor. - Fuelly Forums
Old 01-12-2009, 04:43 PM   #1
greetings.
Time ago, in this forum (dont remember). I read about how to clean the oxygen sensor, an alternative to a buy new O2 sensor. I already searched for that post, but I dont found it. Someone can help me?
mrbass is offline   Reply With Quote
Old 01-12-2009, 08:21 PM   #2
GasSavers_mikemoss's Avatar
If someone knows about this I am very interested in trying it.
GasSavers_mikemoss is offline   Reply With Quote
Old 01-12-2009, 08:40 PM   #3
i found this
http://www.buzzle.com/articles/clean...en-sensor.html
Expose the sensor tip to the torch till it's about to turn red, then dip the sensor tip quickly into water followed by cleaning the tip by blowing compressed air. This will make the carbon deposit to break free. We recommend repeating the procedure a few times until the carbon deposits are removed from the sensor tip.
And then this
http://mr2.com/TEXT/O2_Sensor.html just good info about o2 sensors
I think I will try to test my sensor sometime soon.
Old 01-12-2009, 09:02 PM   #4
Isn't there a ceramic core on oxygen sensors?
- Kyle
Old 01-13-2009, 05:57 AM   #5
yeah pretty sure there is. just replace the thing if it needs it.
zero_gravity is offline   Reply With Quote
Old 01-13-2009, 02:36 PM   #6
some can be expensive, so what about carb/intake cleaner and compressed air?
Old 01-13-2009, 03:12 PM   #7
Cleaning them like this will only work if the failure of the O2 sensor is premature. The catalyst in the sensor that causes the reaction that makes the voltage output will eventually wear out no matter how clean an engine runs.
Unless the engine was just running badly to begin with I've never seen an O2 sensor that had deposits caked on.
It should also be noted that one of the early causes of O2 sensor failure is water condensation.
- Kyle
Old 01-13-2009, 05:57 PM   #8
I've also been told you can clean them by letting them soak in Sea Foam overnight.
Hipermiler
#47 on my way to #1
Old 01-13-2009, 06:04 PM   #9
I'd do a bottle of 99% Isopropyl in the tank and an "Italian tune up"
Old 01-15-2009, 10:58 PM   #10
guest001's Avatar
this is true. I recently got water in my motor, the motors ok, but the o2 sensor failed after I got the car running again.
I have a 1 wire o2. mines only $20 new. yes. I have a wbo2 and it really doesn't take that long at all for the ecu to go into closed loop. I'd be surprised if a heated o2 really put a car in closed loop any faster..,
guest001 is offline   Reply With Quote
Need Help plz! HF tranny codes 78si General Fuel Topics 7 04-01-2009 10:12 PM
Chrysler's New EV Unveiled On CNBC Live! rgathright Automotive News, Articles and Products 17 09-28-2008 05:46 PM
The Monkeywrench Gang by Edward Abbey repete86 General Discussion (Off-Topic) 2 07-26-2008 10:58 PM
New Ride cartuch Introduce Yourself - New member Welcome 5 10-22-2007 03:02 PM
