Removing the water pump... yes? no? - Page 2 - Fuelly Forums
Old 07-05-2006, 07:34 PM   #11
FE nut
diamondlarry's Avatar
two options:
1) leave the gear in place for the water pump, but remove the blades. The gear will still spin.
2) Remove the gear all together and get a bigger timing belt tensioner.
My Saturn's water pump is driven off of the serpentine belt. However, when I replaced my water pump recently(same time as head swap), the drag seemed extremely minimal. I'm not sure there would be much gain for me to use an electric pump. This doesn't mean it wouldn't for someone else though.
2007 Prius,
Team Slow Burn
Old 07-05-2006, 07:41 PM   #12
Water pump could be powered by a fan blade at higher speeds if you let the air flow through the radiator - sort of the reverse of the old days when the belt turned the water pump and fan and pulled the air through the radiator. You need a free wheeling water pump with electric drive or electric clutch and belt drive since a belt may outlast an electric motor... maybe a slotless free spinning electric motor driving the water pump and fan - may as well do both at the same time.
Old 07-06-2006, 01:48 AM   #13
Bunger's Avatar
The do this on drag hondas... suppose to free up some power, so it must increase FE a bit... doubt it would be worth the cost though.
Anger is a gift!
- Zack de la Rocha
Old 07-06-2006, 06:04 AM   #14
Bunger, I saw crx-nation in the signature of someone on h-t and was like, another new forum, eh, I didn't realize it was yours!
Anyway, what's the cost like on said drag hondas?
Old 07-06-2006, 06:45 AM   #15
You can buy electric water pumps for small block Chevy's from a number of places. Most are advertised "for racing purposes only".
Water pumps use a lot of HP at high rpms, but much less at cruising speed. So they help performance more than fuel economy.
Old 07-06-2006, 07:38 AM   #16
DirtyOldTown's Avatar
A lot of people do it on older V8 drag cars but I'm not sure how they'd last on the road. A good friend of mine (and the best mechanic I've ever met, by a long shot) has that setup on his '67 Comet. He loves it for the track but he said on the road it starts to heat up after a while. The benefit to him is that he just turns it of when he makes a pass and then turns it back on while returning to the pits. If you left it off on a cold start it'd probably make the car warm up pretty quick but I'd be nervous about hot spots, like you said JanGeo. As far as the timing belt, it'd probably be best to leave the old pump in place and just get rid of the fins - less risky for the valvetrain in case the belt jumps or breaks.
"Ain't nobody that can sing like me..." Woody Guthrie
DirtyOldTown is offline   Reply With Quote
Old 07-06-2006, 07:44 AM   #17
A water pump is a convenience for designers and manufacturers. A well-designed thermosiphon, or an ebullient cooling system could eliminate this pump.
Old 07-06-2006, 08:09 AM   #18
If I had more room under the hood, I'd probably have rigged an electric motor to drive my water pump by now. Though I doubt the savings would approach the 10% savings I recorded from not running the alternator (@70 km/h).
It's surprising how long the car takes to warm up if you're a regular codfisher though. I drove about a 6 km round trip recently from a cold start, 80F ambient, with the engine off about 50% of the distance. The temp gauge was just rising towards "warm" when I got home.
Good thing too, since my inner tube water pump belt had popped off when I left the house, and was sitting on the driveway the whole time
EDIT: can we estimate this? How could we figure out what the energy requirement is for running a pump at various engine speeds? We could start by looking at the energy requirement spec'd for the electric racing pump, but it likely applies to a V8 application (higher displacement pump than most of us are running).
Old 07-06-2006, 08:21 AM   #19
Matt Timion's Avatar
Odds are this can be done for smaller pumps too, consindering Bunger said that Honda Racers use it. A lot of racers use 1.5L or 1.6L engines.
Old 07-06-2006, 08:34 AM   #20
95metro's Avatar
With a clutch-driven water pump, would the idle-dip before the idle speed sensor kicks in be some indicator of the energy drain on the engine?
95metro is offline   Reply With Quote
More detail josh434 General Fuel Topics 2 06-28-2009 03:39 AM
Fuel Economy and Lease Mileage RespecttheT Fuelly Web Support and Community News 2 08-14-2008 07:42 AM
San Jose Police overinflate tires to 50 PSI to improve performance and have realized significant cost savings..... krousdb General Fuel Topics 10 04-23-2006 05:15 PM
Crazy Spark Plugs Claim Increase of 50% in Gas Mileage SVOboy General Fuel Topics 13 12-29-2005 06:36 AM
