relatively eye pleasing grill block - Fuelly Forums
Old 05-24-2008, 09:42 PM   #1
GasSavers_BEEF's Avatar
I have been on this site for a month or two and have noticed that a lot of people use duct tape and cardboard along with other materials to use for their mods. I have been very particular about the appearance of my vehicle. I want it to look semi-stock at least.
I started with using plastic sheeting for my lower grill and couldn't figure out how to block the upper grill and make it look clean or at least relatively clean. I wanted to still be able to open my hood without having to redo stuff. a friend recomended weather stripping. off to autozone I went. they had a little bit of a selection so I went with the $7.99 10ft roll. I had to use 4 strips to get the thickness that I needed but I think it looks pretty good. here are some pics that are a little hard to see but the best I have right now.
http://www.gassavers.org/garage_imag...ssz5bcpnjo.jpg
http://www.gassavers.org/garage_imag...4mbo0yzmjp.jpg
I also added it around my headlights to create a better seal of the hood.
Old 05-25-2008, 04:58 AM   #2
That looks decent.
Old 05-25-2008, 06:16 AM   #3
On my Regal and my Ram 1500,I blocked them from behind.I don't know if it's any more or less efficient that way,but like you I wanted to keep it invisible.I removed the grille,cut a piece of scrap sheetmetal to fit around all of the mounting points,drilled some holes, and stuck it in. I positioned the mounting screws to go through the grille,then through the block off ,then into the original holes . It kind of makes a grille-sheetmetal-hood sandwich. I might also note that I painted both sides with flat black paint to hide it and to prevent rust.The one I made for the 2004 Ram was made from plexiglass instead.I painted both sides on it too and it is equally invisible.
67 Satellite is offline   Reply With Quote
Old 05-25-2008, 05:43 PM   #4
so your plexi-glass accepted paint?
did you have to scuff the surface before you painted it?
any issues with paint chipping?
I have a friend that wants to do something like that and that is why I was wondering.
I am one that applauds people that will sacrifice looks for FE. I on the other hand want my cake and eat it too.
Old 05-25-2008, 11:11 PM   #5
unstable bob's Avatar
Send a message via AIM to unstable bob
Thumbs up
Krylon has a line of paints called "Fusion" that are made for plastic surfaces. And I've also had good luck w/ regular Krylon, after scuff sanding the plexiglass so the paint would stick better.
unstable bob gable
AMERICAN ROAD WARRIOR!
www.unstablebobgable.com
1973 AMC AMX: The beauty
1987 Buick T-Type: The beast
unstable bob is offline   Reply With Quote
Old 05-26-2008, 06:24 AM   #6
so if you get the better stuff, you don't have to scuff the surface.
I will pass this on. thanks
Old 05-26-2008, 06:36 AM   #7
Nah!,I just used the cheap wal-mart stuff. I think the key is to paint both sides. The paint on the back will give it color and won't be chipped/washed off by weathering. The paint on the front is just to take the shine off of the smooth surface. I used a much lighter coat on the front side.
View model averages? unicrombie Fuelly Web Support and Community News 4 11-09-2011 07:32 AM
Hey guys! TheGreatOak Introduce Yourself - New member Welcome 0 01-18-2008 06:58 PM
super mid Hockey4mnhs General Fuel Topics 5 06-03-2007 01:57 PM
Gas Log? GasSavers_Kraig General Discussion (Off-Topic) 3 08-16-2006 02:21 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 03:44 PM
