Reducing electrical loads - Fuelly Forums
Old 01-06-2007, 06:37 PM   #1
Does anyone know if any were I can get LED driving lights?
I have changed all my lights over to LEDs and want to look into reducing head light draw???
green swift is offline   Reply With Quote
Old 01-06-2007, 08:06 PM   #2
GasSavers_Ryland's Avatar
I have looked around, and as far as I can tell no one makes a bulb for headlights, something I've thought about doing was getting some of the luxeon LED's that are built with voltage regulator and a 1156 or other commen base for use on cars, get one of those, and then polish off some of the reflective coating on your headlight, clear epoxy it in, and wire it up as the driving light, of course this is more complecated if your driving lights are also your headlights, so find out if your head lights as driving lights get the full 12 volts or if they get less to alow them to be dimmer, if they are less, wireing in a switch that turns on the LED if it's lower voltage should do the trick.
Old 01-07-2007, 05:30 PM   #3
You can look into retrofitting an HID system to your vehicle. You would gain from the lower power consumption but take a little bit of a penalty because of the added weight of ballasts.
Dagul is offline   Reply With Quote
MPG versus air temperature and Altitude MensaMike General Fuel Topics 6 06-21-2011 05:16 AM
Tire sizing odometer modifier? BDC Fuelly Web Support and Community News 10 07-25-2009 08:59 PM
Mid-engine del sol SVOboy General Discussion (Off-Topic) 1 03-28-2006 02:20 PM
Probably a Silly idea, but.... krousdb General Fuel Topics 8 03-26-2006 08:10 PM
Sticker Shock -- Inefficient New Furnace rh77 General Discussion (Off-Topic) 8 01-25-2006 06:15 AM
