Originally Posted by Jay2TheRescue
As mentioned earlier, I do not doubt that the roof of a parked vehicle will get hot. What I am saying is when outside temps are low enough to need heat (IE under 60 degrees), that any heating the roof may recieve from the sun would be cancelled out by the 55 MPH (or more) wind going over the roof. A moving vehicle cannot be effectively heated in cold weather by simply painting the roof dark.
I didn't mean anything about actual MPG or temp. change when driving. Here in the south in the summer if a car is completely closed it will easily go above 100F. So, in theory, one could paint the roof WHITE and not use the AC. The back of my truck, even if closed up completely in the summer, doesn't really get that warm at all. I would assume that it has something to do with it being fibreglass, but I also believe it has to do with the white colour. With a sniveling underpowered 4 banger like mine, a VERY noticeable drop in power comes from using the AC (which is why I don't really use it)
