my theory is that some part of your radiator needs to be unblock to insure proper cooling, having your pipes burst due to pressure is a bad thing(your hot enough to be in blown head/ block territory
, first replace the hose, second keep at least a 1/4 of the radiator unblocked, unless you want to crack your head
on my car at prime with wai i had only 2/3 covered 1/3 was exposed and with the wai i only noticed a slight increase in temp increase speed. the velocity at which the tempurature is increasing with is more a rate than anything... so anything much more than that would be way too fast thats why I say 1/4 as a possibly agreeable number, make sure your cooling fan is working too or build a switch for it off a relay if it isn't(worst case scenario)...
i use my old ac condensor as a radiator block currently
