Questions - Fuelly Forums
Old 03-07-2009, 06:09 PM   #1
Why does higher octane burn slower?
Why does alcohol slow down the combustion process?
This text and many others say that Ethanol burns faster than gasoline.
http://www.fuelandfiber.com/Archive/...E85/age85.html
And this:
http://www.eco-flex.us/pages/myths.htm
3. Ethanol burns faster than gasoline but has a slightly longer ignition delay during the slow burn phase of combustion so the engine does not do as much negative work fighting rising cylinder pressures due to large ignition advances. The total ignition advance for E85 is almost identical to the ideal advance for gasoline so it does not cause the PCM problems when you mix them.
vershun is offline   Reply With Quote
Old 03-08-2009, 03:35 AM   #2
Site Team
The correct way to think of it is this way- "higher octane fuel is harder to ignite".
This means the following:
- It is less likely to "diesel" (i.e. ignite without/before a spark)
- The combustion will propagate more slowly (which is different than burning more slowly, read on...)
So first of all, higher octane fuel combusts slower BECAUSE of its higher octane rating (i.e. an indirect relationship, not a direct relationship).
In order to understand, you have to think about how the "flame" propagates through the combustion process after ignition. Think of it as a bunch of individual fuel droplets spread through the combustion chamber. As one droplet of fuel burns, it gets hotter - this heats up the next drop of fuel, which then initiates the burn and releases its energy to the next droplet, and so on. With a higher octane fuel, since it is harder to ignite it requires that the adjacent droplet gets to a higher temperature before the next droplet will ignite. The result that the "flame" will propagate slower through the combustion chamber.
Therefore, the statement that one fuel "burns" slower or faster is meaningless. Does that mean that each droplet will burn faster? Or that the flame will propagate faster? You can't tell by reading the article, the two phenomena are essentially independent when comparing two fuels that have more differences than just the octane rating.
Now if you just compare high octane pump gas to lower octane pump gas, the rules of thumb are that higher octane fuel will:
- Propagate the flame slower
- Be less prone to self-ignition
... BUT, when you are comparing "octane ratings" between dissimilar fuels, the "higher octane" fuel (i.e. the fuel that is more difficult to ignite) could have a faster OR slower burn rate / propagation rate.
Some other points about higher octane fuel:
- Since it is more difficult to ignite, you'll get a less complete combustion (lower MPG, higher unburned hydrocarbons)
- Since the flame propagation is slower, you are essentially retarding the timing (which means your peak cylinder pressure may occur a bit too late to take full advantage of the mechanics of the engine for optimum efficiency)
... therefore your MPG will DECREASE if you use gasoline with too high of an octane rating.
The conclusion is that you should always use the lowest octane fuel for your engine which does not knock.
-Bob C.
p.s. one important followup point: most OEM ECMs run their timing too far advanced IMO, and rely too heavily on the knock sensor to tweak the timing to the correct point. This system works by retarding the timing after it hears knock. This is fine in the short term, but over 100,000 miles these occasional knocks will have an accumulative affect and you could ruin your head gasket.
Old 03-08-2009, 04:05 AM   #3
Wouldn't that point support the practice of using higher octane ratings than specified?
Also, your theory sounds ok but in practice we have the longest lasting engines ever. 181,000 miles on my GMC engine, never had the heads off...should I be looking for signs of cumulative occasional knock damage?
Old 03-10-2009, 01:18 AM   #4
Site Team
Yup - unfortunately, though, it is difficult to tell what's going on with the knock sensor unless you have a scan tool that can give you a KR readout. And even then, most knock is transitional (i.e. during quick throttle changes or shifts).
One more benefit of hypermiling! Since we are generally much lighter on the throttle than the average driver, we tend to stay out of the "transitional" areas where average drivers see the most knock.
For my family's cars (my Saturn and the wife's Taurus), we both use 89 octane under most circumstances. We do this because I can hear the occasional knock when using 87 octane fuels. (I am lucky to have a trained ear that can hear that occasional knock, most drivers will never pick up on it). The 89 octane fuel gives that extra safety cushion to stay out of the knock zone.
-BC
Old 03-10-2009, 04:31 AM   #5
I don't know. My 98 GMC pickup has 160,000 miles on it. It had 109,000 on it when I bought it. Absolutely no problems with the engine at all. I've always gotten better than average mileage in my vehicles, but i've only been actively hypermiling for about a year. Even at that I still occasionally open up the throttle and let the horses out for a run. I think if you're having head gaskets blow at 100,000 miles its not due to a knock sensor, its more likely due to poor vehicle maintenance or poor engine design.
Even running hard the gaskets hold up a long time. I remember at the rescue squad we had an old 86 Caprice with the police package and a 350. It was a Sheriff's car, and the Sheriff's dept gave us the car when they retired it (after 5 years and 110,000 miles) Then the squad had the car for another 5 or 6 years and the car had well in excess of 170,000 miles on it when the head gasket blew.
No civillian in their normal driving could be as hard on their vehicles as a Sheriff's dept and a rescue squad. The car lasted over 10 years and 170,000 miles. The county was a large county, and the squad cars got a workout.
Woo hoo! Got 30.22 mpg in my minivan! GasSavers_rGS General Fuel Topics 17 06-26-2008 05:29 AM
Body kit for MY Kia Rio MrGiff Aerodynamics 1 06-09-2008 04:15 AM
How many of you have "on demand" electricity pricing? GasSavers_Erik General Discussion (Off-Topic) 10 04-21-2008 11:14 AM
thinking about an underbody fairing lunarhighway Aerodynamics 6 10-27-2007 05:17 AM
I just lost 87lbs!!! GasSavers_DoubleJ General Fuel Topics 12 06-26-2007 09:18 AM
