Question on a fuel injector switch - Page 2 - Fuelly Forums
Old 07-09-2007, 06:41 PM   #11
CO ZX2's Avatar
88HF. You just described a bump start!! Ain't that injector switch nice??
Old 07-09-2007, 08:41 PM   #12
cfg83's Avatar
88HF -
Originally Posted by 88HF View Post
I've found that while driving highway speeds in my crx, a bump isn't even necessary to restart the engine. The computer is still on and when you turn the injectors back on and put the car back in gear, let off the clutch, the car starts and pulls until you cut it off again without any trouble.
Like CO ZX2 said, that's a bump-start. My question is, when you do this, do you feel a "jerk" or a "bump" when you put the car back in gear? Also, what is your MPH when you do this? I am curious because I like to know if it feels "rough" or "smooth" in terms of re-engaging the clutch on every person's car.
Old 07-09-2007, 10:14 PM   #13
GasSavers_Ryland's Avatar
when I bump start it tends to be smooth, smooth enough that i have to check my tac to make sure that my engine started, it helps if you open the throttle just a little to give it less resitance when starting.
Old 07-09-2007, 10:15 PM   #14
88HF's Avatar
Thats what I was trying to describe. In my Ranger its more rough (I have to use the key). I put the Ranger in 5th and bump it in 5th quickly then change to the gear I need after start (re-starting in 5th seems to be least resistant). The crx is very smooth with the injector switch, I wouldn't even consider it a bump, I bump it in whatever gear I'm driving at highway speeds, and usually bump in second right before I stop at a stop sign so I don't have to use the key. Very nice indeed CO.
my favorite thread
Old 07-09-2007, 10:47 PM   #15
skewbe's Avatar
I usually select the gear I want to accelerate in ahead of time, set the throttle to about 2/3 and pop the clutch. Bump 'n go, minimal energy and clutch lost on slippage or time spent down shifting.
Standard Disclaimer
Old 07-10-2007, 06:57 AM   #16
Snax's Avatar
MPFI is going to bump start more smoothly than TBI for the same reasons they differ on killing fuel flow.
LiberalImage.com
I think, therefore I doubt.
Old 07-16-2007, 10:29 PM   #17
Originally Posted by cfg83 View Post
88HF -
It's pretty bumpy in mine, probably about to get even rougher after I replace the clutch.
'00 Echo - DD
'11 Kia Rio - Wife's DD
Old 09-04-2007, 12:32 PM   #18
try this:
select the gear you want, then procede to bump-start as normal, but only let the clutch out ~90%, and then quickly reclutch.
it will be enough to get the engine spinning, but as the revs increase it won't be fighting the tranny.
I actually quit nice-off coasting for awhile because the bump start was so brutal in my car. but with this technique you dont feel a thing.
charlesB is offline   Reply With Quote
Old 09-04-2007, 12:38 PM   #19
cfg83's Avatar
charlesB -
Originally Posted by charlesB View Post
try this:
That's a very good description of what I do. One of us should you-tube it.
What is this stat? cavale Fuelly Web Support and Community News 1 09-03-2008 08:23 AM
