Question about Nitrogen - Fuelly Forums
Old 01-18-2008, 06:03 PM   #1
Question Question about Nitrogen
Heard that filling your tires with NO2 helps a bit with mileage and other minor perks. If so where does one fill your tires at with this? Im up in North Florida so hmmm any help is good~
PS I know oxegen is 78% NO2 so yea..
TheGreatOak is offline   Reply With Quote
Old 01-18-2008, 06:27 PM   #2
Whats Notrogen?
I wouldn't do it, but then I'm cheap.
GasSavers_theCase is offline   Reply With Quote
Old 01-18-2008, 07:20 PM   #3
Oxygen is 0% nitrogen. Air is 78% nitrogen. Air is 1% water. Nitrogen is 0% water. Because nitrogen contains no water it doesn't corrode wheels or tires. Its pressure doesn't vary as much with temperature. It doesn't improve fuel mileage if you check your pressure regularly. I get it free, but don't think I'd pay for it.
GasSavers_landon is offline   Reply With Quote
Old 01-19-2008, 08:52 AM   #4
kamesama980's Avatar
Nitrogen at 40 psi will get the exact same mileage as regular air at 40 psi. the advantage is in high-performance track vehicles in the consistency as they heat up on the track there's less pressure change.
If you have corrosion internally from moisture...wow. stop filling up the tires with the hose?
-Russell
Old 01-19-2008, 03:57 PM   #5
To fill tyres with nitrogen you first have to purge ALL the air out which means at least three changes of gas.
ie: Let all the air out. Refill with nitrogen and let that all out. Repeat and finally fill with nitrogen to the required pressure.
After you fill them with nitrogen you have to keep filling them with it so your options on pressure checks and fills are limited.
Finally it has been tested by a few motoring organisations , here in Australia as well as some in Europe , and has found to make no difference to fuel
consumption.
If you want to go ahead I would be interested in what ever you find from your trials.
Cheers , Pete.
GasSavers_Pete is offline   Reply With Quote
Old 01-19-2008, 05:59 PM   #6
GasSavers_bobski's Avatar
Nice.
Really, if you want to fill your tires with some specific gas, why not helium? It conducts heat better than air, is a noble gas making it chemically inert, and is less dense so you'll at least be lugging around a few grams less mass.
Old 01-19-2008, 09:13 PM   #7
I put mercury in mine..Slow off the line but dang it gets some crazy momentum...
Seriously though, dont waste your cash..
Old 01-20-2008, 08:22 AM   #8
GasSavers_Ryland's Avatar
they use it in air plane tires because of the tempeture change between being 1,000's of feet in the air where it's cold and having the tire hitting a runway and suddenly heating up.
nitrogen is also inert, and dry, so it will not brake down the rubber, nitrogen molicules are also reasonably large, so they are less likely to seep thru the poors in the rubber.
in my mind nitrogen filled tires would be best for vehicles like motorcycles and bicycles, they often have tubes, so purging is not an issue, and it will make the tire last longer while in storage.
Lawn edge side skirts holypaulie Aerodynamics 6 06-06-2010 01:51 PM
Sort by MPG? adjustafresh Fuelly Web Support and Community News 4 09-05-2008 08:05 AM
My Fuel Economy Goal... trebuchet03 General Fuel Topics 16 09-08-2007 08:06 AM
Team Challenge Results: What did you learn about FE? DRW General Fuel Topics 62 06-10-2007 07:59 PM
Arggg.... Hooray For Proprietary Fluids! trebuchet03 General Discussion (Off-Topic) 2 05-08-2007 10:03 AM
