PVC catch device - Fuelly Forums
Old 01-09-2007, 03:19 PM   #1
PVC catch device
A link was posted in another thread about this device . How many of you are using the PVC catch device and with what results ? I know the thread is from about 7 months back by SVOBoy . Seems to be a good idea and one I'd invest in (especially since it's so cheap to do ) Thanks !
GasSavers_RunningOnFumes is offline   Reply With Quote
Old 01-09-2007, 03:35 PM   #2
Somewhere in the thread it noted how many people were running it, but I'm not quite sure. While I am sure that a lot of the honda people are, I also forget who.
Anyway, it is ridic cheap, so yeah, good luck,
Old 01-09-2007, 05:46 PM   #3
|V3|2D
thisisntjared's Avatar
<--i did it
it does the most if you clean you the intake manifold right before installation. a lot of oil builds up in the intake manifold after many miles
Old 01-09-2007, 09:54 PM   #4
Count me In
I've been running one for a little over a year now --
I too installed it after a Seafoam cleanse to start and stay gunk-free.
So far, over about 30K miles, it has collected about 25mL of residue.
I'm not really sure how to quantify the benefits, other than the goop isn't flowing back into the intake, clogging the injectors, and building up carbon elsewhere. Also, it isn't being burned burned-off into the atmosphere, which is also a plus.
An old pic:
Old 01-09-2007, 10:20 PM   #5
GasSavers_Diemaster's Avatar
if i can find the PVC line on lisa i'll install it. have the parts just too lazy
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 01-10-2007, 10:35 AM   #6
kickflipjr's Avatar
I had one on my saturn. And will put one on the mazda soon.
2008 EPA adjusted:
Old 01-10-2007, 11:11 AM   #7
GasSavers_TomO's Avatar
I also have been running the El Cheapo catch can since late November with good results. Results as in seeing how much gunk is not going into the intake manifold anymore. I also did a de-carbonizing treatment to my engine before installing it.
Honda Civic VX Info/Links
Old 01-10-2007, 11:52 AM   #8
GasSavers_Ryland's Avatar
so have there been any problems, or side affects of installing one of these?
Old 01-10-2007, 12:45 PM   #9
Not Sure
The PCV system was designed to collect blow-by vapors that would normally be emitted into the atmosphere, and instead re-direct them into the combustion process and through the catalytic converter on its way out.
With that in mind, I see no reason why the collection of the by-product of combustion would cause a problem, as this device wasn't intended to operate in engine to start with. As long as the PCV valve is operating and allowing gasses to escape, and there's no buildup in the crankcase, the one-way valve system of the collector allows air/gas to flow while cooling the gasses down into liquid form for collection. It must be changed regularly or else the gunk will certainly go directly into the intake. Depending on how fast the bottle fills, I've emptied mine at each oil change (and check it regularly).
Some have a concern that this goo somehow lubricates the top-end during the combustion process, but nearly all modern gasolines have additives that aid in this process.
Old 01-10-2007, 05:14 PM   #10
Here's the fancy one they sell for Fbody Gm with LS1's for $90 . I'll be using the El Cheapo version as well . Thanks for the input , folks ! Jim
http://www.ws6project.com/user_stor/...399fd24821c976
RSS feed for friends activity udtrev Fuelly Web Support and Community News 2 07-26-2009 12:47 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Which chart do you like better? Matt Timion General Discussion (Off-Topic) 20 03-05-2006 01:52 AM
