Pumping losses - Fuelly Forums
Old 05-16-2008, 07:51 AM   #1
Originally Posted by dosco View Post
I'm not sure I can hit crazy MPG numbers by worrying about throttle angle and RPM alone - the other variable is the HP created. This defines the fuel used.
<sigh>
I think I need a scangauge.
Unfortunately, as I found out in another thread, the SG doesn't actually measure fuel flow and some of the other important variables it displays. Instead, it calculates them. Be aware of that as you consider buying it for precision measurement of such things.
Old 05-16-2008, 10:16 AM   #2
Fair enough, but the next logical question: what device out there actually measures fuel flow in passenger cars?
Old 05-16-2008, 07:15 PM   #3
Just a guess.
I think you're good guesser.
please use the built-in quote feature
Sorry, I know I'm a major offender in this regard. I should realize it's probably annoying. I'm just so used to doing it the old-fashioned way, but I'll give it a try.
I'm avoiding open loop.
OK, that's what I figured. Thanks for explaining; I think you explained it very well.
I think one of the interesting things about open-loop is that it's something my car generally doesn't do, as far as I can tell. I think a characteristic of wideband-sensor systems is that open loop occurs only when the engine is cold, or when there's some kind of a sensor failure.
But I understand why avoiding WOT makes sense in your situation.
I can't tell if it's lagging a few seconds in its readings or if it really doesn't go into open loop easily
Interesting question. I don't know what that lag is about. With my DMM, I can monitor my O2 sensor directly, and the response is immediate. That is, I can see AFR changing right away, as I move the throttle. But you're reading info indirectly, with Vag-Com getting the data from your car's computer in OBD format (I think that's how it's working; I could be wrong). That's a more complicated process, so it's harder to tell where the delay is being introduced.
Coming out of open loop, I could see how your car's brain (ECU or ECM or whatever VW calls it) could choose to lag and hold open loop for a few extra seconds, for good reasons. But I would think that going into open loop would be immediate, when you floor it under certain conditions. After all, the idea is to give you good throttle response, and provide the power you're demanding. Also to prevent an overly lean mixture from hurting your motor. So it should happen without a lag, I think.
I have been tried P&G (neutral, not EOC) and it looks promising.
I think coasting in neutral is a very powerful technique. I think it's easy to underestimate the drag created by coasting in gear, and I think this drag probably overwhelms the benefit of DFCO.
EOC is great, but it requires very specific driving conditions.
Old 05-16-2008, 07:15 PM   #4
Originally Posted by R.I.D.E. View Post
more resistance at WOT
You're claiming, literally, that there's "more resistance at WOT." I have a lot of trouble grasping how we create "more resistance" when we remove a restriction that is preventing air from entering the engine.
Think about the Jake brake on big rigs, they are using trapped compression, not vacuum, obviously they can't use vacuum
Yes, a diesel can't create engine braking with vacuum, because it has no throttle. Engine braking in a gas engine is the result of the engine fighting the vacuum created by a closed throttle.
If you were correct that there is "more resistance at WOT," then it would be possible to maximize engine braking on a gas engine by using WOT (with the injectors off, of course). With current drive-by-wire systems, this could be easily accomplished. I wonder why no one has ever built an engine that works this way. Then again, maybe you know of one?
Aside from all that, I have no idea what point you're trying to make by mentioning diesels and Jake brakes.
in my previous example with 185 pounds of compression you have over ten times the resistance that 14.7 negative pounds of vacuum would ever produce
For some reason you're comparing the compression cycle to the intake cycle, but I have no idea why. As dk pointed out, the energy put into compression isn't wasted. It's like compressing a spring. We get it back a moment later (aside from a bit of frictional loss) on the power stroke.
On the other hand, the energy that goes into fighting the throttle restriction is waste. We don't get it back.
I wish I could prove when lean burn is engaged. Since that is not possible
But it is possible. Thanks to the helpful instructions posted by TomO and others, in various places, it's not hard to do. You just need to put a DMM across D14 and D16. At Harbor Freight, DMMs start at $4.
If you monitored your lean burn, I imagine that you would notice things that would be helpful to the rest of us. Since you're not monitoring your lean burn, I have a hunch that there are quite a few moments when you think you're in lean burn, but you're not. It's very, very sensitive to throttle position; you can rapidly move from lean to rich with a very small increase in throttle angle.
lean burn was possible in lower gears and climbing grades
Yes, you can climb a hill and maintain lean burn. Provided it's not too steep and you're not going too fast. And yes, you can cruise at fairly high speed (60+) and maintain lean burn. But it's very hard to maintain lean burn in any gear, if you are conducting any form of acceleration. Unless the acceleration is exceedingly moderate.
We disagree on when lean burn is actually occuring.
Yes. But a difference worth noting is that I've monitored it directly with an instrument, whereas you're essentially making a bunch of guesses based on imprecise statements you've read in various places.
Of course the light does not come on in 5th gear, but you can still use the same throttle position percentage.
Because lean burn is so sensitive to small throttle movements, I don't think you can count on your ability to maintain lean burn based on the idea that your foot is able to remember the exact angle it was holding a few seconds ago. If you had an instrument reading your Throttle Position Sensor, that would be a different story.
Somewhere I saw a photo of someone who rigged a hand throttle, for this purpose, essentially. You would need that kind of precise control to really be able keep the throttle in exactly the best position to maintain lean burn.
To me it makes no sense that the light would be on when lean burn was working but off when it wasn't.
It might make no sense to you, but that's still what the light does (under certain conditions). If the light goes on, and then you increase the throttle setting by a certain amount, the light will go off. Even though you haven't obeyed the light and upshifted. And at this moment, lean burn is off and so is the SIL. Go figure.
I think you're oversimplifying the relationship between lean-burn behavior and SIL behavior.
Mr Honda was a pioneer in lean burn technology, going back to the stratified charge prechamber CVCC engines in the 70's.
Yes. In 1980 I bought a '78 Civic CVCC. A great car. It looked a lot like this: http://www.hondaclassiccars.co.uk/images/Dcp_1052.jpg
Old 05-16-2008, 07:16 PM   #5
to get an idea of fuel flow rate I plugged in the hp number for given RPM numbers for different load lines. Lo and behold that at less-than-ideal RPM and throttle settings, I can easily reduce the rate of fuel flow. In other words, at 2,000 RPM on the 50% load line I can use less fuel per hour than at 2,500 RPM at 100% load
I'd like to understand what you did, but I'm having trouble following this.
Old 05-16-2008, 07:16 PM   #6
Originally Posted by Dalez0r View Post
use them according to driving conditions
Originally Posted by dkjones96 View Post
thermal efficiency is by far the biggest player in all of this.
I think these statements, and the rest of the comments from which they are taken, do a really nice job of summarizing what we're talking about.
Old 05-16-2008, 07:16 PM   #7
SuperMID. And this: http://forum.ecomodder.com/forumdisp...mputer-26.html
Not much else, that I'm aware of.
Old 05-17-2008, 03:50 AM   #8
You have the links to the SFC and BMEP isopleth charts? The links are on this board, Pale originally posted them, I reposted in other threads.
You will note on the SFC charts that there are a number of iso curves, each iso curve represents a particular engine load - 25%, 50%, etc. The curves show that each load has a different efficiency, and that 100% load is most efficient.
The next step is to realize that the units of SFC are lb/hp-hr. So if you know what SFC your engine is operating at and how much hp is being produced, you can calculate the fuel flow rate.
I used the SFC chart for a "typical 2-valve 4 cylinder engine" and was able to find a dyno run graph for my car. Multiplying the hp number from the dyno chart with the SFC number that corresponds with a particular engine RPM yielded fuel flow rate. I calculated points on each iso curve to compare flow rates.
Old 05-17-2008, 04:53 AM   #9
Hmmm now that's an idea... that or the MAP reading...
Old 05-17-2008, 06:35 AM   #10
I can see what you guys mean about more resistance at WOT than with a closed throttle. We know that a vacuum pump will only give so much resistance, a compressor can continue to increase in the amount of resistance offered depending on the amount of pressure it needs to put out.
It makes sense that there would be more 'loss' in an engine at WOT if and only if we are talking about an engine that isn't running at all but being turned by an outside source. If the engine is running it's completely different. We all know that raising compression makes for better fuel economy and more power overall. It's the main reason diesels are so efficient.
As for making a throttle-by-wire system that engine brakes at WOT, they won't do that because all that cool air in the exhaust would cool the catalytic converter(s).
- Kyle
Small problem with the 'recently' section and UK MPG DarkBahamut Fuelly Web Support and Community News 1 01-27-2009 01:11 AM
Retire a Vehicle pb Fuelly Web Support and Community News 1 11-11-2008 03:30 PM
suggestion for stat comparison zahampton Fuelly Web Support and Community News 1 09-04-2008 07:29 AM
Grill Blocking/Air Intake...Work in Progress DarbyWalters General Fuel Topics 5 12-15-2007 07:53 PM
ENERGYSTAR DIY Guide to Sealing Your Home Mayhim General Discussion (Off-Topic) 1 12-12-2007 04:41 PM
