Project: KDA (Engine and Auto to Manual Swap) - Page 37 - Fuelly Forums
Old 06-26-2006, 07:42 AM   #361
Muchas gracias para la ayuda.
Old 06-26-2006, 08:39 AM   #362
If you get using the Camera again, would you take a shot of the intake's. I can imagine what Bunger was describing about the intake runner's, but you have the head and a picture would help a bunch. Thanks, Gary
Old 06-26-2006, 08:40 AM   #363
Ah, I was planning on doing that anyway, I'll do it right now!
Old 06-26-2006, 08:45 AM   #364
Old 06-26-2006, 09:12 AM   #365
Last interior piece to go in the car:
Thanks matt!
He also got me the rear mount I've been missing, but who cares about pictures of a rear mount,
Old 06-26-2006, 09:14 AM   #366
Thanks for the picture's, that answers a lot of my question's. On looking at this, it look's to me like if your going to use the 8 valve head, your intake manifold is different in both size and bolt configuration. If I've followed this, correctly, your DPFI to MPFI change included an intake for the 16 valve head. It look's to me like you might have an alignment/disconinuity in your intake, if you try to put the 8 valve head on your car. Doe's my question make any sense?
Old 06-26-2006, 09:16 AM   #367
Actually, one of the big things going for the 8 valve head is that I ended up using the 8 valve intake manifold on my car, so right no a have a big discontinuity that will be fixed with the new head.
Old 06-26-2006, 09:19 AM   #368
Ah, so!
Old 06-26-2006, 09:21 AM   #369
Indeed, I think it shall work out quite well. Timing belt and water pump will also be done with the swap, so hopefully everything works out. I'm about to call around for some valve spring compressors so I can pick some up tonight.
Old 06-26-2006, 09:34 AM   #370
Well, the valve spring compressors are in stock, thanks to the guy who told me last night they didn't have anything like that.
Ethanol pianoeck General Fuel Topics 5 05-25-2010 01:01 AM
It's Bunger Bunger Introduce Yourself - New member Welcome 15 03-02-2006 06:20 PM
