Project: KDA (Engine and Auto to Manual Swap) - Page 6 - Fuelly Forums
Old 05-18-2006, 10:06 PM   #51
ahks's Avatar
i should post up some pic's of the cx engine i have on my engine stand funny thing... i unexpectedly grabbed all the parts for an almost identical build as his
92 cx block/head HF Cam
HF Trans
gonna rebuild this engine
re-ring
bearings
gaskets
cylinder hone
all i need is the chunk of wiring harness from ecu to engine bay and i wont even have to make a conversion harness
ahks is offline   Reply With Quote
Old 05-18-2006, 10:44 PM   #52
GasSavers_Diemaster's Avatar
Talking
u bought a EG manual. i had one U COULD HAVE GOTTEN FOR FREE!!! *insert feeling like a jackass here* :P
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 05-19-2006, 01:21 AM   #53
philmcneal's Avatar
Originally Posted by krousdb
My engine is never at idle. It is either under load or it is off.
interesting.... if its not too late SVOBOY happy burfday to you to. Sounds like a swap is such a good present as well as the knowledge.
one more thing, i wish i had a lighter flywheel, my revs take too long to drop since I don't let the sycros do any work.
Old 05-19-2006, 04:41 AM   #54
Darn!
Philllllllllllllllllll: You can prolly get a lighter flywheel if you wish it.
Old 05-19-2006, 05:03 AM   #55
is it necessarily the flywheel? i have heard that the ECU limits rapid (non-load) RPM drops as an emissions control measure. sorry i can't point to a source - just some hearsay.
Old 05-19-2006, 09:29 AM   #56
|V3|2D
thisisntjared's Avatar
this could be true, but but a few of my friends have lightened flywheels and you can feel the difference while shifting up and down. heel toe is much easier and also shifting up is faster.
i dont see how rapid drops in rpm would be bad for emmisions...
Old 05-19-2006, 11:28 AM   #57
philmcneal's Avatar
Originally Posted by SVOboy
Darn!
kak what can I do with a flywheel if i can't do my own oil change :P
wee roll it on the street maybe it can teach me something or two about coasting!
^^ i thought only electronic throttle position (like 8th gen civics) do that hmmmm interesting.
Old 05-19-2006, 11:45 AM   #58
FE nut
diamondlarry's Avatar
My Saturn seems to do something like this. If I'm moving at all while the engine is running, my idle speed is around 1200rpm's. When I come to a complete stop, the idle drops to it's normal 550 rpm's.
2007 Prius,
Team Slow Burn
Old 05-19-2006, 11:48 AM   #59
Moderator
GasSavers_DaX's Avatar
I know my 1988 Civic idles at about 1200 until I come to a complete stop, like Larry said.
Old 05-19-2006, 01:12 PM   #60
Got my timing belt and water pump today, I couldn't double use my rewards card cuz of one day, but meh,
Ethanol pianoeck General Fuel Topics 5 05-25-2010 01:01 AM
It's Bunger Bunger Introduce Yourself - New member Welcome 15 03-02-2006 06:20 PM
