05-19-2006, 06:45 PM
#71
Originally Posted by MetroMPG
good thread, svo. things are going full steam ahead.
where do you work that you have access to a shop & machining tools?
I am interning at Ceriale's Automotive in Mt. Holly, NJ. I learned how to turn rotors today, but no one has done a flywheel so that'll be a first if we can figure it out with mine, the machine is made for it so it should be fine.
Thanks, I'm excited about this, in a second I'll have a gearing post and then the stuff I promised earlier,
05-19-2006, 06:46 PM
#72
Hey, look at my fancy gearing:
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear
500 3 6 10 13 15
600 4 8 12 16 19
700 5 9 15 18 22
800 5 10 17 21 25
900 6 12 19 23 28
1000 7 13 21 26 31
1100 7 14 23 29 34
1200 8 16 25 31 37
1300 9 17 27 34 40
1400 9 18 29 36 43
1500 10 19 31 39 46
1600 11 21 33 42 50
1700 11 22 35 44 53
1800 12 23 37 47 56
1900 13 25 39 49 59
2000 13 26 42 52 62
2100 14 27 44 55 65
2200 15 29 46 57 68
2300 15 30 48 60 71
2400 16 31 50 63 74
2500 17 32 52 65 77
2600 17 34 54 68 81
2700 18 35 56 70 84
2800 19 36 58 73 87
2900 19 38 60 76 90
3000 20 39 62 78 93
3100 21 40 64 81 96
3200 21 42 66 83 99
3300 22 43 68 86 102
3400 22 44 71 89 105
3500 23 45 73 91 108
3600 24 47 75 94 112
3700 24 48 77 96 115
3800 25 49 79 99 118
3900 26 51 81 102 121
4000 26 52 83 104 124
4100 27 53 85 107 127
4200 28 55 87 109 130
4300 28 56 89 112 133
4400 29 57 91 115 136
4500 30 58 93 117 139
4600 30 60 95 120 143
4700 31 61 98 122 146
4800 32 62 101 125 149
4900 32 64 102 128 152
5000 33 65 104 130 155
5100 34 66 106 133 158
5200 34 68 108 135 161
5300 35 69 110 138 164
5400 36 70 112 141 167
5500 36 71 114 143 170
5600 37 73 116 146 174
5700 38 74 118 148 177
5800 38 75 120 151 180
5900 39 77 122 154 183
6000 40 78 125 156 186
6100 40 79 127 159 189
6200 41 81 129 162 192
Calculations done here and gear ratios retrieved here!
Thanks to andrew bense for the help here, for those of you that know him.
EDIT: Damn formatting, my eyes hurt!
05-19-2006, 07:17 PM
#73
Moderator
Sounds like you broke the pintle cap on one of the injectors SVO. They are designed to protect the pintle...you'll be fine without it, as long as you don't drop it again.
Originally Posted by zpiloto
I'm curious do you think that if you could increase the fuel pressure to the nozzels would that help the spray pattern or do you think that they would just leak under the pressure.
If the injector pintle is clean, the spray pattern is already idealized. Honda injectors use a pintle (sort of like a solenoid operated needle valve) instead of a disk to open the fuel orifice. Essentially an injector is just a solenoid. Increasing fuel pressure won't do a whole lot for you. Increasing a little will allow more fuel to get through the orifice during PULSE ON. Increasing the fuel pressure too much can hinder the injector's ability to open (just think, if there is 100 psi, this injector first has to push back against that to open the orifice before it allows any fuel through) and actually cause a lean condition.
05-19-2006, 07:19 PM
#74
Didn't even have to search to find someone 10x cleverer than me. Too bad my auto to manual swap is gonna get done before his,
Thanks for the pintle information, Daxxxy, but I figure I'll replace it anyway since I can get a free set from a friend and the one does have a bad o-ring,
05-19-2006, 08:12 PM
#75
Ben your 5th is exactly like my 4th. Once I get some taller tires I'm hoping to be 2000rpm at 65mph instead of 2200rpm where I am right now with smaller tires. My stock tires allowed me to be at 2100rpm at 65mph. I should have never went with smaller tires.
05-19-2006, 08:15 PM
#76
Do you know what your final drive is? I knew we had the same gear size there but I never knew what your FD was.
05-19-2006, 08:25 PM
#77
It's 3.619
My current tire size is 205/60/15. As you can see by the calculator when you calculate I made it worse for me.
05-20-2006, 05:18 AM
#78
Woot! A 192 MPH car that gets 70MPG! Dood! you are my hero!
05-20-2006, 06:08 AM
#79
boost and lots of it. As a matter of fact I seriously doubt even with boost his car will achieve that. Gears tend to break up under a lot of power. The only gears that will hold up to a lot of power are the 1st 2 gears. They are built to withstand a lot of damage. The strongest gear in a car is actually the reverse. You ever notice that is makes a loud noise when you go backwards, it's because it's straight cut. The straight cut gives it the best durability and strenght, the problem is it's very loud. Race cars now only use straight cut forward gears. Gears are cut at an angle in common cars for the forward gears to reduce noise, plus most cars are not that powerful.
05-20-2006, 06:21 AM
#80
|V3|2D
dude on reallly really super low speed technical auto-x courses, you would never have to get out of 1st gear!! im telling you race h stock!! hahaha
