06-23-2006, 08:29 AM
#331
I've been thinking about airflow, and I still want to do the headswap, but if someone tells me the cam swap will work it'd be nice to toss it in there while I get the money for the head swap!
06-23-2006, 09:24 AM
#332
SVOBoy: It looks to me like all Honda did was to build the head without the additional valve's in it. I can't see any reason why the 8 valve cam wouldn't work just fine on the 16 valve head.
I think the primary reason that the HX only put's out 70HP is probably, largely because of not having the second valve in the head. From what I've read it sounds live the VX just resolves that issue by allowing the second valve's to come on above 2000 rpm.
One possible issue: On the information I've read on the VX head, they keep the second valve's open a miniscule amount to keep fuel from collecting in the top of the second valve. I don't think this would be an issue because you never would be opening the second valve's.
Possibilities!
06-23-2006, 09:27 AM
#333
Yes, I have had worried about the possibility of fuel puddling. Anyway, I'm kinda worried it'll be a ton of hassle to do the cam swap and not be worth it until I do the head swap.
Any insight on this?
06-23-2006, 09:35 AM
#334
Even if a cam swap was possible, swap the heads. The runners on the 8V head are very different than the 16V.
Anger is a gift!- Zack de la Rocha
06-23-2006, 09:41 AM
#335
SVOBoy: I don't know if you would encounter any problems, but doing the cam swap is pretty easy, for someone with your skill's. Basically you have the following step's.
-loosen timing belt and slide off of cam.
-remove distributor
-remove cam bearing cap bolt's
-pull camshaft out.
-reverse the whole process with the exchange.
-reinstall timing belt
-reset timing on distributor
I don't think it is a real big deal, to try it. Additionally, all you lose is the time to change it back. After seeing your picture's, I think that your biggest problem will be that you will be at the 70HP, because of your reduced valve capacity, which you would have anyway, if you do the whole head. I'd certainly give the 8 valve cam a try, just because it's not to big a deal, you can't hurt anything and you will most likely get the same results as if you had swapped the whole head assembly.
06-23-2006, 01:18 PM
#336
|V3|2D
exactly
06-23-2006, 04:58 PM
#337
SVOboy: So what does it mean when you say it has longer runner's. I was under the impression that it was talking about the length of the intake manifold. ?
06-23-2006, 04:59 PM
#338
Bunger: You referenced longer runners for the VX head. So, what does that mean?
06-23-2006, 05:39 PM
#339
The runners are different in the head, not sure if they are longer (or shorter). If you've ever looked down the intake ports on a 16V head, you can see how the passage way splits into 2, each going to two different valves. By just having one valve not open, you're not going to get very optimal air flow. The same goes for the exhaust side.
06-23-2006, 05:58 PM
#340
So, what your saying, I think, is that on the head with only two valves, that Honda changed the porting to optimize the flow for the single valve?
