Project: KDA (Engine and Auto to Manual Swap) - Page 24 - Fuelly Forums
Old 06-09-2006, 06:04 PM   #231
It's the color code for Barbados Yellow, which was a rare (but sexy) color that came on CRXs. It is also cursed, now you know.
Old 06-11-2006, 10:30 AM   #232
Matt Timion's Avatar
Originally Posted by krousdb
Both the CRX and the Del Sol came in different trim levels. Both had trim levels with 13" tires (CRX HF and Del Sol S) and 14" (CRX Si and Del Sol Si). Rather than having different VSS sending units or gauge clusters, they prolly used the same ones. So since the 14" trim levels had the larger tire diameters, the ODO/Speedo was calibrated to those and that made the 13" trim levels over register. This is just my hypothisis. I have no proof whatsoever to verify such hypothisis. Yes, I am willing to admit that I am guessing here.
I'm guessing that the 14 inches tires + wheels were roughly the same diameter as the 13 inch tires + wheels. For the 13 incher they probably used 175s, and on the 14 incher they might have used 160s or 165s. I'm sure that was the easy solution to the problem.
Old 06-11-2006, 11:56 AM   #233
I guess we'll never know!
Old 06-11-2006, 05:22 PM   #234
SoonSoonSoon!
Originally Posted by SVOboy
Budomove, when do you wanna do your tranny? I'm free anytime now and I'd like to get some practice so mehbe I can get a few clutch jobs this summer,
Congratulations on graduating!
I am ready to swap, but need to work next weekend, how about sometime the following weekend? June 23-25. friday, saturday or sunday. I have class mon-thurs. Please let me know...Frank.
budomove is offline   Reply With Quote
Old 06-11-2006, 05:35 PM   #235
I will have to yack about, but since you're so close it shouldn't be a biggy, 23rd or 24th seems good to me, as of now.
Thank you, by the way, la la la.
Old 06-11-2006, 09:30 PM   #236
la la la.
My thoughts exactly,
and no, Thank YOU!
Old 06-13-2006, 07:54 AM   #237
UPDATE:
I've got some work tomorrow so I should have sufficient dinero to buy a d16y8 head gasket from honda and an IM gasket from who cares where. This means that I will be doing the head swap with the b8 head sometime next week (hopefully squeezing it in to 2-3 hours and not having anything blow up).
What this means for those not in the know is that my engine will become functionally equivalent to an entire d15b8. Of course the block is different but those differences don't mean to much as it is the head casting, valve configuration, and cam that defines most of how the engine functions.
CRX Stats For Loving (I've used the CRX HF as a Parallel of the Civic CX, even though the engines are ever so slightly different, first is HF and second is DX):
Fuel Type
Regular
Regular
MPG (city)
49
32
MPG (hwy)
52
36
MPG (combined)
50
33
Old 06-13-2006, 08:07 AM   #238
Compaq888's Avatar
love the new cluster. It looks so much better than your oem cluster.
Old 06-13-2006, 08:09 AM   #239
Well, if you wanna get picky, it is an oem cluster, but yes, it recieves much love from me.
Old 06-13-2006, 08:10 AM   #240
I forgot to mention the HF gets 51% better FE than the DX, just so you don't have to do the math.
Ethanol pianoeck General Fuel Topics 5 05-25-2010 02:01 AM
It's Bunger Bunger Introduce Yourself - New member Welcome 15 03-02-2006 07:20 PM
