I didn't forget pictures, I thought about it and said no, for a swap like this a first timer won't do the best stuff and it'll kill on time, mehbe next time.
Just got back from the junkyard, they closed early so I went under the fence (bad decision, yes) and got most of the stuff I needed besides the rear mount. As I was going to leave some money near the door under a rock (as per what the guy said it would cost) I noticed he and some people were there, so I went over there and was thorougly reemed for breaking into his yard (I deserved it, yes). Eventually he decided not to call the cops (because I was honest about where I lived and worked and he recognized me from calling) and I gave him the money and left extremely disappointed with myself for doing something so disrespectful even though I had the best of intentions to leave money for the stuff.
, bad day, and it's my fault, of course.
Anyway, on to the swap (bolded are things I've got the stuff to do, not necessarily done though):
(Buy) Very long bolt from starter to block, mine is bent somehow
(Buy) VSS plug
(Buy) Cluster plugs
(Buy) Rear mount, tranny portion
(Buy) Side mount, both pieces
(Buy) Misc. shift linkage bolts
(Buy) New shift linkage pin, from Honda
(Do) Plug in VSS. TPS and other sensors we moved out of the way
(Do) Figure out what to do with the transmission cooler stuff
(Do) Hook up the OEM traction bar on the passenger side
(Do) Reverse and park wiring
(Do) Flywheel Sheild Installation
(Do) Hook up the clutch cable
(Do/
Buy)
Driver side CV boot
Jared, thank you again, for all the help. My side mounts were actually correct, but the one was missing a bolt. I looked at where the hook together and can't figure out the stuff, but yeah.
