Project KBA, KMA - Page 18 - Fuelly Forums
Old 09-03-2006, 02:11 PM   #171
zpiloto's Avatar
Originally Posted by krousdb
Just installed the Belly Pan, Grille Block and front wheel spoilers on the VX.
I also installed all of the instrumentation that I had on the Del Sol. The Dash is pretty full but I am well informed now. Notice the accuracy of the Air Speed Indicator. This was a leasurely drive in the park from a cold start. The 35.55 km/L translates to 83.5ish MPG.
Looks like someone is getting down to bussiness. There could be a shake up in the top 10 soon. Every body better bring there A game to GS.
Old 09-04-2006, 09:23 AM   #172
tomauto's Avatar
Send a message via AIM to tomauto Send a message via MSN to tomauto Send a message via Yahoo to tomauto
Well
I forgot to mention that I don't think that the VX is running right. When I had the Del Sol and was playing around with a chipped ECU, I put in the one that Ben sent me and when I started it up, it threw a CEL and stunk bad. Truned out to be a bad ecu. When I first started the VX it smelled the same way and had a CEL. After changing the O2 sensor, the smell was reduced but not totally gone. The DMM shows that it idles lean but is still smells bad. Im concerned that it won't pass emission testing.Does anyone have a clue what could be wrong? Bad cat? Bad EGR?
In this article, it says that only the California Emmissions VX had the EGR in it. So, that means that you are releasing more Nox into the air....which would be why you have the funny smell....
I found that bit of information on page 19 and 20 of this article
http://72.14.209.104/search?q=cache:...=clnk&cd=11See
Current Stable
tomauto is offline   Reply With Quote
Old 09-04-2006, 10:26 AM   #173
Dan, when you did the belly pan on the Del Camino, were you able to estimate how much it helped? I could search for this, but I'm being lazy.
Old 09-04-2006, 11:51 AM   #174
krousdb's Avatar
Yes, I have read that article and have noted the error before. the 49 state VX's have the EGR also, or at least mine does. The CA version has EGR also but does not have lean burn.
Old 09-04-2006, 11:55 AM   #175
krousdb's Avatar
I added the belly pan and the HX wheels, LRR tires all at once. the net increase was 4 MPG at 55 MPH. I can't tell you how much difference each made separately.
Old 09-05-2006, 06:58 PM   #176
So, did you go to work today? Any numbers with the pan/block/spoilers?
Old 09-06-2006, 02:16 AM   #177
krousdb's Avatar
It was cold and rainiy, numbers were a few MPG lower. Not a good day for comparison. I wouldn't expect to see much on my commute. Hoping for something on long highway runs, like I will be doing starting 9/18.
Old 09-11-2006, 03:55 PM   #178
krousdb's Avatar
I have completed several mods that are meant to maximize the highway FE, which after getting some results, I will share here. My belly pan is complete with aluminum ala basjoos and the pan includes the muffler. I have wheel spoilers at all 4 but they actually rake forward which is prolly not a good thing. I removed the XM antenna and stuck it on the rear hatch out of the air flow. I removed the FM antenna and installed a blockoff plate. I am also driving with the drivers mirror folded in and am using a blind spot mirror mounted inside the car to give better visibility. I also have the coroplast wheel covers cut and painted with Krylon Fusion silver. I will mount them using clear RTV this Saturday before I leave Sunday morning for the 640 mile trip to the beach.
I will commute to work from the beach (225 miles, 4.5 hr RT)for a few weeks before I close on the house. Then the commute will be down to 135 miles, 2.5 hr RT. I'm hoping for some nice results but I really don't have much to compare with due to the new commute so the gains won't really be quantifiable until I remove the aero mods for NC inspection in Dec or Jan.
I will stop rambling now.
Old 09-11-2006, 04:25 PM   #179
zpiloto's Avatar
Will you get a better break on winter weather and a later arrival of winter blend moving south?
Old 09-11-2006, 04:36 PM   #180
krousdb's Avatar
Yes, I hope to have more moderate winters.
higher Octane = Better MPG JBW General Fuel Topics 9 04-04-2012 12:54 AM
Multiple Vehicles of the Same Type: Gordon861 Fuelly Web Support and Community News 4 12-02-2009 04:28 AM
All about acetone in fuel acirrone General Fuel Topics 17 10-11-2008 02:51 AM
suppress vehicles showing "0 mpg" billcharlton Fuelly Web Support and Community News 3 08-20-2008 03:30 AM
Fixed Gear DirtyOldTown People Powered 7 07-04-2006 07:05 AM
