06-01-2006, 12:40 PM
Neither can I...I have no tach, not even a "silly" digital one.  I need to find a Metro LSI cluster. They had tachs.
06-01-2006, 01:06 PM
Mwahaha, my new tach is up and running and I very much like it.
'Nuff said.
06-01-2006, 01:26 PM
i shift when it hits the rev limiter... dosnt everyone???
all joking aside
when im being good (accelerating to 90 - 120kph)
idles at 650
into 2nd at 1400
into 3rd at 1800
into 4th at 2300
into 5th at 2500
in the city with traffic behind me (accelerating to 60 - 70kph)
idles at 650
into 2nd at 2800
into 3rd at 3000
into 4th at 2500
into 5th at 2000
..shaner
2001 Saturn SL 1.9 SOHC 5spd - 41MPG @ 91,000kms
06-01-2006, 01:41 PM
1st gear
6100 rpm 44mph
2nd gear
6100 rpm 74mph
3rd gear
6100 rpm 125mph
4th gear
umm a lot
06-01-2006, 08:36 PM
|V3|2D
compaq, you dont make any sense. read what this thread is about, then edit your post.
06-01-2006, 10:12 PM
It's about shifting a manual. i was being sarcastic. i can make my auto shift at any rpm I want, it just depends how much I press the gas pedal.
06-02-2006, 04:02 AM
Yes, the point of the thread is where you actually make it shift. Any of us can shift wherever we want.
06-02-2006, 07:18 AM
Can you elaborate a little on that. I would love to know how to make my auto shift 5 MPH sooner.
06-02-2006, 07:53 AM
#19
Originally Posted by Sludgy
JanGeo said:
"Should be an adjustment for those shift points on that Ford Truck automatic."
I found diesel programmers that are set up for efficiency. Most just dump more fuel into the truck at low revs, and advance the injection. The engines make more black smoke after these mods. One (Edge Performance) also claims to let you alter the shift points (at WOT) and hydraulic oil (clutch) pressure without touching the engine programming.
I'm going back to GM trucks as soon as I can.
When I talked to Miro at Synlube he said a lot of the diesels are built in Mexico rather poorly and they blow up or fail and make a lot of noise when running from poor machining tolerances. Full throttle is injecting too much fuel - I see it here all the time and there is no need for it - back off a little - acetone is supposed to reduce the soot and black smoke - 2 oz per 10 gallons.
06-02-2006, 08:46 AM
#20
1st gear is 1600rpm
2nd gear is 1600rpm
3rd gear is 1600rpm
If people are really on my *** then
1st gear 1750rpm
2nd gear 1700rpm
3rd gear 1750rpm
