Plugged into the grid? - Fuelly Forums
Old 08-30-2006, 09:53 AM   #1
ZugyNA's Avatar
I have an "AC Adapter" wallwart type transformer that was made to charge a 12V DC drill....that I've setup to try and charge the batt in my car.
I have a connecter from RS wired to the battery ...it hangs out of the grill down behind a driving light...so it might not get ice encrusted in winter.
Should just have to plug the transformer in and connect it for juice.
Works...but it seems to get a little warmer on the car battery than the drill.
INPUT: 96mA
OUTPUT: 400mA
Questions:
* what will it cost to run this over every 24 hrs...assuming an avg electric rate?
* what is the efficiency of this small transformer using grid power vs the car's alt?
* will it keep the battery charged?
* will it last...or will it overheat?
The battery probably needs replacing...does fine in summer...but if it sits in winter it will go flat.
I've heard that a failing battery can reduce mpg due to the alt constantly having to charge it.
True?
Fuel Consumption on High Altitude judacomadc General Fuel Topics 18 10-04-2011 01:26 AM
