Plasma Coating & MPG Revisted - Fuelly Forums
Old 01-25-2007, 09:40 AM   #13
Ok will check again with my brother since he is involved with high performance motorcycle repair all the time - ones that go over 150mph turbo charged etc on the ceramic coatings from Hartford.
The EMC Teflon impregnation is a process where the parts cleaned of any oils then are heated in a high pressure teflon gas chamber and the teflon penetrates into the pores of the metal. Parts of the metal surface can be masked for no treatment. Crank journals - pistons rings and skirts below the ring grooves - wrist pins - gears and shafts - shifter forks - valve stems and steel valve guides (not brass guides I don't think) - cams and lifters all can be treated. Also any shaft that is rubbing upon an oil seal greatly reduces the friction and wear on the seal. They used to do gun barrels for weather protection for miltary purposes also - not sure if they still do it. They refuse to do bullets however so don't ask. Different metals with different heat treatment / hardness get heated to different temps and pressures. Buildup is possible on parts if you want it but it can be easily removed i.e. piston wrist pin holes. Like I said it makes the parts incredibly slippery - even being aware of how slippery the wrist pin was ahead of time I still dropped it. This is the transmission and rear end treatment that I used on my BMW motorcycle that brought it up to 60mpg from 50mpg and performance increased as well from the reduction of friction in the drive train allowing the bike with a roll on starting at 60mph to reach redline in a few seconds in top gear - speedo indicating 120mph.
As far as the additives in the oil I also use them but they tend to take longer to show results as they have to be burnished into the metal surfaces and as to if they work or not the recent addition of slick50 gear treatment to my xB transmission showed that even a 20 year old can of the stuff can still work.
Think about it for a second - oil is mostly providing a film to keep the metal surfaces apart so the only time the PTFE particles actually get rubbed into the metal is when metal to metal contact is occuring - heavy loads or low RPMs with reduced oil flow/pressure or in the case of the rings at TDC and BDC when the velocity of the piston is zero for a split second and at startup and low lugging speeds.
$2,000 for used 100mpg "car" GasSavers_Ryland General Fuel Topics 24 08-02-2006 06:37 PM
we got the Geo! GasSavers_Ryland General Discussion (Off-Topic) 3 07-24-2006 06:05 PM
