Placing a screen under the throttle body - Page 2 - Fuelly Forums
Old 03-11-2008, 10:10 PM   #1
GasSavers_SD26's Avatar
The screen obviously reduces the area of the intake. Might just help increase the intake velocity. I've seen that done with epoxy on some racing motorcycle intakes.
Looking forward to your follow up.
Dave
Old 03-12-2008, 07:06 PM   #2
kamesama980's Avatar
That's a completely different thing. the screen will increase velocity for the franction of an inch of it's thickness but the air will slow down again as soon as it's past it. using epoxy in the manifold/runners is to eliminate dead space and therefore eddies in the air as it flows through. it keeps the velocity constant and reduces destructive turbulence
-Russell
Old 03-12-2008, 03:41 AM   #3
The doubling of the gasket is probably more a contributor to the seat-of-the-pants improvement than any restriction you've added.
You've begun on your way to creating a 'high-rise' manifold, a long known performance enhancer.
Old 03-12-2008, 07:16 AM   #4
Well, I already have a TB Spacer under the TB. I placed the screen under the TB spacer.
I am looking forward to seeing how this pans out as well as I am barely able to afford gas for this thing as it is.
Reishi is offline   Reply With Quote
Old 03-13-2008, 09:00 PM   #5
Interestingly enough, a college used this trick to convert a car to run on Ethanol, this, as well as a bit of heat made the ethanol atomize to combust even on the coldest of days. The only problem i see with this ( as well as on mechanical injection systems" is that an intake block, will make you have to open the throttle more to get the same power, but with out an o2 sensor (i have one hehe) it will not know that it is getting less air than it usually does at this throttle opening.... Rich booo.
Old 03-15-2008, 05:10 PM   #6
So should I invest in one of the O2 sensor trickers?
Recovering faster from partial fill-up hufman Fuelly Web Support and Community News 12 01-12-2010 02:16 AM
Chart suggestions jeadly Fuelly Web Support and Community News 0 08-08-2008 02:46 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
Best way to do a lowering experiment? MetroMPG Experiments, Modifications and DIY 34 11-02-2006 04:01 PM
