Ping Sming and bad gas - Fuelly Forums
Old 09-13-2006, 07:57 PM   #1
lovemysan's Avatar
Filled up the tank yesterday, 8 gallons at a phillips 66. I pulled in the station and noticed 4 nozzles at each pump. No diesel though. I thought it odd. One was some type of mixed gas it had a label that I didn't read. So I selected 87oct and filled up. 20 minutes later the car starts pinging like a 84 subaru. It was most certainly caused by the gas. I removed the 110 ohm resistor and it went away for the most part(woot this thing has more power than hemi now).
So what happened, did I get some funny gas blend? It annoys me that you can't tell how crummy certain fuels are until you pay for them.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 09-14-2006, 05:47 AM   #2
Moderator
GasSavers_DaX's Avatar
I heard on the radio yesterday that gas companies are beginning to switch to winter blend already...could this be the cluprit?
Old 09-14-2006, 06:47 AM   #3
kickflipjr's Avatar
was it Ethanol. E10 ussually comes in 89 octane so I don't know.
2008 EPA adjusted:
Old 09-14-2006, 09:11 AM   #4
Even if the gas companies are beginning to switch, theres a 6 week window for the first drop of winterblend to hit the consumer gas stations.
And ethanol does separate out of gasoline...ethanol is some of the octane number...you prolly got like 85 octane fuel running through your system. It's okay, your computer will adapt around it.
I've had it happen to me too. I was really really good at getting the same fuel for 1000miles then I switched and kinda shocked the computer out of its extra fine tune. It pinged and pinged, I finally had to reset the computer only because mine is so slow and stubborn to adapt.
-unknown
Old 09-14-2006, 09:20 AM   #5
Maybe you got some E85 instead of E10 - better go back there and see what it was before you do some fuel system damage.
