picked up a paseo! - Fuelly Forums
Old 03-02-2008, 11:32 AM   #1
picked up a paseo!
So after getting fed-up with my expensive gas guzzler this winter, I boughy my friend's 92 paseo, 300 000 KM on the clock but still starting like new .
The car has a block heater, and I plan to use it. I also expect to cut increase my fuel economy by a little less than 50% VS my WRX.
EPA rating for the 5 speed paseo 28/34, which isn't that impressive for a 2025 lbs, 99 HP 1.5 liter, but I expect to drive it so it gets more than that .
Hurray for frugality
Rayme is offline   Reply With Quote
Old 03-02-2008, 11:46 AM   #2
The Tercel with the 5E-FE was meant to do 45mpg highway. So if it's geared different, sticking a tercel final drive in it might get good numbers.
Old 03-03-2008, 02:35 PM   #3
You may want to check out Daox on ecomodder.com forum
http://ecomodder.com/forum/showthread.php?t=701
Getting mid to high 40's on his '97 Paseo.
I also have the 1.5L Toyota engine in my Scion xB. About 300lbs heavier than the Paseo and my last fill up I got 38.8MPG. We'll see if I can repeat it to verify it wasn't a fillup fluke. So I imagine on your Paseo you should be able to get above 40 pretty easily!
goyogi is offline   Reply With Quote
Better gas mileage for an RV 73challenger General Fuel Topics 5 10-31-2007 05:08 AM
rants skewbe General Discussion (Off-Topic) 20 08-11-2007 04:08 PM
Always lookin for better MPG HEK Introduce Yourself - New member Welcome 1 06-28-2007 05:04 PM
D00ds, we needs stickers/window clings SVOboy General Discussion (Off-Topic) 20 10-06-2006 11:21 AM
Depend on Honda to solve Ethanol problems tomauto Vegetable Oil and BioDiesel 9 09-26-2006 09:40 PM
