PIB as a fuel additive
Hi everybody. I just found this message on Yahoo! Better MPG group. Vey interesting. I've already ordered my quart of Torco 2-cycle oil and will begin testing when it gets here.
Larry
Date: Wed Oct 12, 2005 10:19 am
Subject: Re: http://www.sciencenews.org/articles/20000902/fob3.asp mjoosting
Offline
Send Email
I've just read from members of Bobistheoilguy.com that polyisobutylene
(PIB) can be found inexpensively from some synthetic 2-stroke oils.
The normal composition of PIB in these oils is around 30%. The
purpose of which is to add lubricity to the fuel and allows the oil to
burn cleanly without soot. An example of a 2-stroke oil that has PIB
is TORCO Smokeless 2-stroke oil that, although expensive, is composed
of 38% PIB.
PIB supposedly works by binding the different sized HC's into larger
droplets. The PIB looses its grip above a certain temperature
dispersing the molecules and allowing them all to burn at the same
time. In this paper
http://www.gtatech.com/downloads/OctaneBoosterPaper.pdf they claim
>20% improvement from only 10ppm PIB. Adding this minute amount of
PIB into your gasoline would require one to dilute about 1 ounce of
PIB-containing 2-stroke oil into 1 gallon of gasoline and then adding
only 1 ounce of the gasoline mixture into each tank of gas.
Obviously, a bottle of 2-stroke oil might last the lifetime of the car
it was used for.
2007 Prius,
Team Slow Burn
