People with MPGUINO - Page 4 - Fuelly Forums
Old 04-28-2013, 01:39 PM   #31
sebass's Avatar
Thank you. That helped a lot. I still would like to find clarification on few parameters like
Pulses/2 revs = 3ul default but Per wiki jap cars are 1. Confused here!????
Injector DelayuS = 500 ul ...that's default but wifi specific for VX is blank. Does that mean 0 or 500...???
VSS Delay ms = 2 ul .....not sure what VX specific would be ???
Her is what i extracted from my 0.86 code and what you provided if anyone whats to use it.
MPGuino Default settings
Cut out of officeal MPGuino 0.86 code
unsigned long parms[] = { 55ul, 8208ul, 500000000ul, 3ul, 420000000ul, 10300ul,
500ul, 2400ul, 0ul, 2ul, 0ul, 0ul };//default values
char * parmLabels[] = { "Contrast", "VSS Pulses/Mile", "MicroSec/Gallon",
"Pulses/2 revs", "Timout(microSec)", "Tank Gal * 1000",
"Injector DelayuS", "Weight (lbs)", "Scratchpad(odo?)", "VSS Delay ms",
"InjTrg 0-Dn 1-Up", "Metric (1=yes)" };
Contrast = 55 ul
VSS Pulses/Mile = 8208 ul Civic VX value
MicroSec/Gallon(Custom Value to car) = 269113500. Yoshi SuperMID designer value custom to Civic VX.
Timout(microSec) = 420000000 ul ...dispaly timeout. Can be anything.
Tank Gal * 1000 = 10300 ul ...assign custom value to your car = 10000 = 10 gal tank
Injector DelayuS = 500 ul default
Weight (lbs) = 2400 ul default ....change to 2094 lbs
Scratchpad(odo?) = 0 ul
VSS Delay ms = 2 ul
InjTrg 0-Dn 1-Up = 0 ul
Metric (1=yes) = 0 ul
rbhollabaugh gassaver.org member settings
#define usedefaults true
unsigned long parms[]={45ul,8208ul,269113500ul,3ul,60ul,10300ul,500ul,2 400ul,0ul,2ul};//default values
char * parmLabels[]={"Contrast","VSS Pulses/Mile", "MicroSec/Gallon","Pulses/2 revs","Timout Minutes",
"Tank Gal * 1000","Injector DelayuS","Weight (lbs)","Scratchpad(odo?)","VSS Delay ms"};
Contrast = 45 ul
MicroSec/Gallon = 269113500 ul
Pulses/2 revs = 3 ul
Timout Minutes = 60 ul
VSS Delay ms = 2ul
sebass is offline   Reply With Quote
Old 04-28-2013, 01:45 PM   #32
sebass's Avatar
double post. edited and deleted.
Old 04-28-2013, 04:44 PM   #33
sebass's Avatar
Ok did some testing and 3 is DEFINITELY INCORRECT!!!!!! Wiki says 1 is for all jap cars and on 1 my car gives good value where on 3 its weird so i don't trust it. I reset delays to defaults although i'm not convinced that's correct. Guy that sells Jelly bean version drives Geo so Geo values can not be applied to VX. No way
Old 05-05-2013, 02:14 PM   #34
VX_Arky's Avatar
so why did spotaneagle get banned?
VX_Arky is offline   Reply With Quote
Old 05-05-2013, 07:53 PM   #35
He was banned for political posts after he had received many more warnings than he should have been given.
Old 05-06-2013, 04:50 PM   #36
VX_Arky's Avatar
Thanks. I'm a reporter, and curious by nature!
150x150 sig davejsw Fuelly Web Support and Community News 2 05-22-2009 07:50 AM
Driving improving FE? Nate R Hypermiling 9 04-11-2008 08:32 PM
removal of factory air dam 91CavGT Aerodynamics 2 08-27-2007 07:54 AM
100 mpg car? minic6 General Fuel Topics 42 08-11-2007 08:49 AM
Any guess on what MPG gains I'd get if I removed power steering and air conditioning? cheapybob General Fuel Topics 24 04-27-2006 05:11 AM
