Originally Posted by Bill in Houston
The max voltage for each junction is low. You'd need a lot in series to make 12 or 14 volts.
(DOPE SLAP)
Well...looks like my inexperience is really showing!!! I was reading this COMPLETELY wrong!! For
cooling it is a
Peltier Effect, for
power generation it is a
Seebeck Effect.
http://customthermoelectric.com/tecs_vmax.html
So for this model:
12711-9M31-24CW (200?C rated)
The
COOLING rating for a 60C temp difference requires 24.0 amps / 226.1 watts / 15.2 volts.
The
POWER GENERATION rating is 5.23 amps / 22.5 watts / 4.30 volts @ a 200?C
Hot Side & 25?C
Cold side temp difference. Sure does look like at least 3 would be needed to do much.
Dang!! Now I understand...thanks for being patient with me everyone!!
