P&G and cat temperature cycling? - Fuelly Forums
Old 06-06-2008, 08:18 AM   #1
Exclamation P&G and cat temperature cycling?
I was logging some data this morning, and saw that in many P&G cycles, my catalytic converter temperature goes from ~500 degrees C to ~850 C and back. Even in more typical ones, there's still a ~250 degree C spread. Could all this heat cycling cause early failure?
Could the spread be much larger today because of wet weather, and on a dry day with no splashed water cooling the cat it wouldn't vary as much?
I'm not too concerned on my VW because it will be covered under warranty long after I return the car from its lease, but it may be bad for my truck and it may mean more to others here...
Old 06-06-2008, 01:57 PM   #2
kamesama980's Avatar
I've only heard of damaging a cat through rich/oil burn (clog), melt (lean), or mechanical (hit it) damage. it's meant to take sub-zero to 900+ degree temperature cycling day in day out, I doubt 500-850 (which is 350 difference btw, not to be nit-pickey or anything :-p) is gonna bother it.
-Russell
Old 06-06-2008, 04:34 PM   #3
My concern was the quantity of heat cycles. In general usage, it heats up and fluctuates much less during use than with P&G.
The 250 number was for "more typical" P&G cycles than the ones that resulted in the 350 difference.
Old 06-06-2008, 05:00 PM   #4
There's really only one way to be sure.
"I say we take off and nuke the entire site from orbit." -Ellen Ripley
Old 06-07-2008, 05:27 PM   #5
My point was that 900*+ sweeps do no appreciable damage over 20 years in a healthy engine. zero times fifty is still zero
-Russell
Old 06-07-2008, 05:49 PM   #6
Well, I'll let you know in 40,000 miles when I turn in my lease.
Add Groups? ScoutTech Fuelly Web Support and Community News 3 03-17-2010 11:35 PM
CL 1993 Geo Metro XFi GasSavers_Red For Sale 2 08-06-2007 05:30 PM
