over unity electric engine - your thoughts - Page 4 - Fuelly Forums
Old 07-28-2006, 06:08 PM   #31
I knew the martians had something they were holding back from us all these years.
Old 07-28-2006, 07:46 PM   #32
GasSavers_maxc's Avatar
They live over there and here.
less lurking and more working
Old 07-29-2006, 12:38 AM   #33
Send a message via AIM to molecule
yeah thats the hardest thing i have convincing all my clients too
must be relatives
cant see the forest from the trees
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 08-01-2006, 07:01 PM   #34
what do you get when you connect high voltage/low amp power to low volt/high amp power in parallel or whatever...?
BE ZEITGEISTED
Old 08-01-2006, 08:22 PM   #35
The voltage pushes the amperage, so the high voltage side will win. What are you trying to accomplish?
vegasjetskier is offline   Reply With Quote
Old 08-02-2006, 08:00 AM   #36
what do you mean wins...?
lets say i have 35A/5.5volts & 35mA/11kV
and then i connect both power lines together
BE ZEITGEISTED
Old 08-02-2006, 09:04 AM   #37
Voltage is like water pressure. It pushes the amperage (water) through the wire (hose). If you connect a high voltage line to a low voltage line, the high voltage circuit will overcome the low voltage circuit and electricity will flow backwards through the low voltage circuit.
What are you trying to do and why would you connect these two lines together?
Old 08-02-2006, 01:37 PM   #38
deja vu...again
alright...well looks like i need to do some physical tests
maybe a diode so energy can flow in one direction
BE ZEITGEISTED
Old 08-02-2006, 02:25 PM   #39
Question
So do you want to have a serious discussion or are you just trolling?
What are you trying to accomplish and why do you want to connect those two circuits together?
deja vu...again
Old 08-02-2006, 02:28 PM   #40
The magnetic field is generated by the current flowing through the wire in an electromagnet. You need both.
Originally Posted by maxc
The magnetic field comes from the "current" or the "wire"? In a electromagnet.
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 04:31 PM
