Opinion: Best Fuel Injector/Intake Cleaner - Page 7 - Fuelly Forums
Old 05-09-2010, 03:46 PM   #61
Mine is better!
My way is best!
Do this!
Do that!
How about finding comparisons that use a common test method?
Here is the Amsoil test standards:
Standards
by Ed Newman
AMSOIL Marketing & Advertising Manager
This article appeared in National Oil & Lube News, March 2006
In 1986 I caught a PBS show that featured Tom Peters, author of the 1982 bestseller ?In Search of Excellence.? If you are familiar with Tom Peters you know his style is designed to shake things up. He doesn?t pull punches and at this point in time he was very harsh on U.S. companies for their lack of commitment to high standards.
The story I remember best is about a company that made hydraulic systems. They had sold one of their systems to a Japanese firm and after the unit was assembled and in operation there were six leaks with hydraulic fluid running out. The Japanese firm called the U.S. manufacturer to complain, but instead of the U.S. rep apologizing or offering to help resolve the issue, he defended the leaks. He said, ?There are 600 joints in that system. There is only one leak per 100 joints and that is pretty good, wouldn?t you say?? Now remember, this is a hydraulic system.
The point Peters made was not rocket science, just common sense. Applied common sense is probably Peters? claim to fame. In order for a hydraulic system to operate there should be no leaks. This, therefore, must be the standard for any manufacturer of hydraulic systems.
Around that same time I did a photo shoot for an AMSOIL ad that involved an old Toyota and a new Corvette. During the shoot I noticed something interesting. The bead of caulk around the windshield on the Corvette was applied in such an irregular and primitive manner that it was dreadful. The same windshield bead on the Toyota was perfect all the way around. This was a very expensive Corvette. I am not trying to be harsh, but it was evident there were different standards of quality applied by the two companies and you had to ask yourself, ?If what I can see is so poorly done, what about the things I can?t see??
BY WHAT STANDARD?
What is the measure of lubricant quality? There are two organizations especially devoted to the development of standards, the American Petroleum Institute (API) and the American Society for Testing and Materials (ASTM).
The API came into existence around the time of World War I. After the breakup of Standard Oil, the competing independent oil companies were brought together to ensure that petroleum supplies would be efficiently deployed to the U.S. armed forces. After the war this informal association of oil companies became officially established as the American Petroleum Institute.
At first they worked on standardizing oil field equipment. Eventually they began to standardize best practices and set minimum standards for oil quality.
Though not specifically an oil industry organization, ASTM develops uniform procedures that can be duplicated and verified by laboratories in any location. The goal of establishing standards is so important that the official publication of ASTM International is called Standardization News.
Founded in 1898 and completely voluntary, ASTM is now one of the largest non-profit standards development systems in the world. The organization currently has 134 committees that write standardized test methods for materials, products, systems and services. More than 8500 ASTM specifications have been established for products as diverse as metal, paints, plastics, textiles, energy, consumer products, medical services and instruments and even the environment.
Developing standard measurement methods is part of the task of ASTM. Equally important is determining what measures are important, tests that actually correspond to what the function of motor oil is intended to fulfill.
What follows here are some ASTM tests commonly used to evaluate motor oil performance.
ASTM D-445 Kinematic Viscosity
ASTM D-2270 Viscosity Index
ASTM D-5293 Cold Crank Simulator Apparent Viscosity
ASTM D-3829 Borderline Pumping Temperature
ASTM D-97 Pour Point
ASTM D-92 Flash Point and Fire Point
ASTM D-4683 High Temp, High Shear Viscosity
ASTM D-4742 Oxidation Stability
ASTM D-892 Foaming Tendency
ASTM D-5800 Noack Volatility
ASTM D-4172B Four Ball Wear Test
These are just a few of the common bench tests that lab directors and chemists have selected because they measure variables of lubrication that are critical to engine performance. Tests such as high temperature, high shear viscosity and oxidation stability are among the most important, but each of the tests plays a role in determining the value of a motor oil. And when you get to the bottom line, it?s an undisputed fact that by nearly every measure today?s premium synthetic motor oils are superior to conventional petroleum oils. This truth is never even questioned by industry professionals.
The key to identifying a quality lubricant is not by its advertising claims or memorizing the color of a label. In fact, standardized tests have shown that even within a product line there can be inconsistent levels of performance.
Hollywood films are often made memorable by a single line. In the Tom Cruise film Jerry Maguire, Cuba Gooding Jr. not only stole the show, he also brought home an Oscar with that now famous demand, ?Show me the money.?
In our industry, when it comes to performance the words I look for are, ?Show me the data.? Objective test results are the true measure of motor oil quality. What this means is that when your customer is running synthetics, good things are happening under the hood.
Ed Newman is Marketing & Advertising Manager for AMSOIL INC.
Old 05-09-2010, 03:59 PM   #62
i know we're off topic, but i gotta support shatto on this...
price regarding true synthetics is a moot point because there are less frequent changing intervals--so i no longer debate it, it's dead. besides, time saved is money saved, period.
my thoughts go to the "extreme" NOW situations. heat and cold. if your car gets hot, synthetic is what you want. overheating can happen anytime to any vehicle, well maintained or not. that's cheap insurance.
how many know that cold does not weaken batteries? heat and time do. however, when it gets cold, the "thicker" oil taxes the battery at start up. having a synthetic w/ lower pour point combats this.
so for you "long term" doubters, that there's some short term benefit!
Old 06-13-2010, 04:44 PM   #63
ran across this...http://www.cruzinperformance.com/injsteps.html in regard to injector cleaning and the process thereof. pretty cool!
Old 08-11-2010, 07:02 AM   #64
Re: Opinion: Best Fuel Injector/Intake Cleaner
seafoam now has this...http://www.seafoamsales.com/sea-foam-spray.html w/ a funky straw shape to reach deep inside throttle bodies.
Old 12-11-2010, 01:07 PM   #65
Amsoil n seafoam for the win
Everett is offline   Reply With Quote
Old 12-17-2010, 10:59 PM   #66
Dr. Jerryrigger's Avatar
Well I guess theoretically this is somewhat true, but a battery will give a lower voltage and fewer amp in the cold, just ask an EV guy. The oil will cause very little difference, as when your starting the car; the engine has almost no oil in it. If you turn you engine by hand (with a socket wrench) I doubt you could really feel a difference hot weather vs. cold (based on working on my POS's in all types of honorable weather). But it's easy to see the voltage of your bat. change with the temp.
I picked up some sea foam a few weeks ago at Walmart when I got my winter jug of 0W30. I ended up changing the oil in a hurry before a trip, so I didn't mess with the SF in the oil. The bottle makes it sound as though it's fine to add to your oil and just, well, forget about it. I would think that it would evaporate and burn off (mostly through the PCV), but I'm a little hesitant to add anything to my oil. And if it did work than my oil would get really dirty, and need to be changed.
I once tried an oil additive which you put in just before and oil change, it didn't pass my test, but it didn't do anything bad.
Old 12-20-2010, 08:26 AM   #67
I once put seafoam into the oil, and went about 70 miles before draining the oil. The oil didn't look different when it came out, after sitting , a lot of sludge settled out of it.
Old 03-10-2011, 10:46 AM   #68
FYI...
don't know if it's nation wide, but my local advance auto parts had shell v-power fuel system cleaner on clearance for 95 cents(12 oz, up to 20 gal treatment). i bought the last 8!
Old 03-10-2011, 10:57 AM   #69
tradosaurus's Avatar
FYI...
AWWW CRAP! No wonder I couldn't find any there!
tradosaurus is offline   Reply With Quote
Old 03-10-2011, 04:54 PM   #70
add|ct's Avatar
FYI...
Ha! I did the same thing. Called a friend and he went by an Advance Auto Parts closer to him for 11 bottles from their shelf! I may hit up one tomorrow morning to clean house again.
'92 Civic VX, Canadian model
Find friends disappears after adding a friend tggbenz06 Fuelly Web Support and Community News 2 08-30-2008 05:14 AM
