One year at gassavers (summarized) - Fuelly Forums
Old 04-02-2009, 05:16 AM   #1
GasSavers_BEEF's Avatar
I have been at gassavers for a year now and have filled up 36 times (average 3 times per month). I have increased my mileage by utilizing the scangauge and other inexpensive vehicle modifications. The entire list is in my gas log. Here are the numbers that I have been playing with.
Averages:
MPG: 34.5856
MILES/TANK 462.8944
GALLONS/FILL 13.39992
PRICE/FILL $41.61656
PRICE/GALLON $3.081684
Max and Min:
MPG: 40.0077---29.91692
MILES/TANK 531.5---361.6
GALLONS/FILL 15.329---9.547
PRICE/FILL $58.3599---$22.63305
PRICE/GALLON $4.209---$1.759
Totals:
MILES: 17132.4
GALLONS: 495.249
COST: $1526.201
Savings over EPA:
MILES=17132.4
GALLONS=495.249
IF 25MPG, GAL=685.296
DIFFERENCE=190.047
SAVINGS @ AVG PRICE=$585.6647.....
I haven't kept up with price in my gas log on here but I have in my personal gas log. the reason this year has saved me so much money (unfortunately) is because of the spike in gas prices this summer. it is sad that I have put almost $60 worth of gas in a cavalier.
hopefully the coming year will do me even better.
*edit* I found an extra gas log entry in my gassavers gas log. it was druing hurricane ike and my wife had my car so it didn't go into my personal gas log. numbers have been updated.
Old 04-02-2009, 05:29 AM   #2
Anything work better or worse than you expected? The amount you estimate you saved is about equal to my entire yearly gas budget!
co de pen den cy
Function: noun
Date: 1979
Old 04-02-2009, 05:52 AM   #3
the combination of the grill block and the WAI seems to have helped out quite a bit.
the aero hub caps was a wash but it made the car look nice. I am cheap and didn't go for the full moon caps.
the extended air dam was also a bit of a disappointment and I scraped everything.
the single biggest improvement was the scangauge. along with the MPG readout, it allowed me to experiment more because of the other readouts that it gave me. I have also used it to diagnose problems with other peoples vehicles. I keep a spare cable in the car so that I can easily remove it to check CEL codes.
Old 04-02-2009, 06:17 AM   #4
I haven't been here a year yet but I do have over a year of log entries.
I have filled up 48 times (average once every 7.5 days).
Averages:
MPG: 22.42
MILES/TANK: 278.4
GALLONS/FILL: 12.475
PRICE/FILL: $36.22
PRICE/GALLON: $2.922
Max and Min:
MPG: 27.98---18.22
MILES/TANK: 406.7---146.4
GALLONS/FILL: 16.906---7.039
PRICE/FILL: $60.50---$14.00
PRICE/GALLON: $4.049---$1.659
Totals:
MILES: 13361.8
GALLONS: 598.807
COST: $1738.65
Savings over EPA:
MILES=13361.8
GALLONS=598.807
IF 25MPG, GAL=668.09
DIFFERENCE=69.28
SAVINGS @ AVG PRICE=$202.43
Hopefully the coming year will do me even better as well.
GasSavers_NovaResource is offline   Reply With Quote
Old 04-04-2009, 04:50 AM   #5
MPG based on 28 samples
Minumum : 24.14
Maximum : 42.61
Std Deviation : 3.77
Average : 31.70
95th percentile : 39.24
Percentage of EPA : 163.50%
$/gal based on 28 samples
Minumum : 1.69
Maximum : 3.999
Std Deviation : 0.69
Average : 3.11
95th percentile : 4.49
Cumulative savings calculation
((Miles/EPA)*Cost) - ((Miles/MPG)*Cost))
((8419.40/24)* 4.49) - ((8419.40/ 39.24)* 4.49))
$ 611.75
this data was calculated by a program written by a good friend of mine and is as accurate as the data used.
Yesss! Got 30mpg bowtieguy Transmissions and Running Gear 25 01-25-2008 12:49 PM
I did the unthinkable today... EOC Matt Timion General Fuel Topics 35 11-18-2007 08:08 AM
VW Rabbit Diesel Engine flow work hotroddr General Maintenance and Repair 5 02-14-2007 06:34 AM
How I made my ****ty auto torque converter lock up without an auto ecu SVOboy Transmissions and Running Gear 17 03-29-2006 06:54 PM
Seriously Considering an Import (Literally) rh77 General Discussion (Off-Topic) 5 03-24-2006 09:18 PM
