Old Tires, Higher RR? - Page 2 - Fuelly Forums
Old 05-23-2007, 08:02 PM   #11
Hockey4mnhs's Avatar
yup i think im gonna invest in lrr tires soon
Old 05-24-2007, 05:33 PM   #12
|V3|2D
thisisntjared's Avatar
Contact patch is largely a function of weight vs. tire air pressure, so, I doubt it.
and the elasticity of the treads has nothing to do with contact patch? no matter what compound, the lower the tread, the less elastic, right?
Old 05-24-2007, 07:36 PM   #13
pretty sure clench is right. it would only change in extreme cases where the sidewall starts to support a lot of weight, usually possible only in a verrrrry low profile tire or a run-flat.
Old 05-25-2007, 01:20 AM   #14
caprice's Avatar
I replaced bald tires with a set of 2 year old hardened stock tires from a diesel pick up and I got worse braking traction. Also had other experiences with using older tires. I test drove a Mitsubishi eclipse with dry rotted back tires that made it want to slide out on turns. Usably the old tires had little visible cracks too.
David
85 Chevrolet. 30 MPG or bust!
caprice is offline   Reply With Quote
Old 05-25-2007, 05:59 AM   #15
Oh, yeah, the traction is DEFINITELY going away. Time for new shoes...
Old 05-25-2007, 03:11 PM   #16
brucepick's Avatar
One thing with new tires is the diameter is larger due to tread not worn away.
So actual distance covered per rotation is more - but your speedometer doesn't know this.
The difference vs. a half-worn tire isn't that much - but vs. a worn-away tire the difference is more. If you make speedometer stay at same speed you used to (with worn tires) the engine is actually working harder because it's driving the car faster. But the odometer shows slightly less miles.
If you stay off the gas a bit you likely will get better ACTUAL mpg but it won't show on the odometer. Like having a slightly taller final gear ratio.
Old 05-26-2007, 05:53 PM   #17
I can use all of that that I can get. :-)
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 02:12 AM
More fun on FUELLY brytrkr1 Fuelly Web Support and Community News 3 12-06-2009 11:41 PM
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
Feature suggestion: website badges acheslow Fuelly Web Support and Community News 4 08-11-2008 03:19 AM
Newb FAQ Red Tick General Fuel Topics 4 06-15-2006 02:34 PM
